Escape throttle sticking. - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 01-08-2010, 11:56 AM
99F350PS 99F350PS is offline
99F350PS is starting off with a positive reputation.
Wife has an 2005 escape with 4 cyl engine. The throttle sticks when it is cold outside. Anyone else have or had this problem. lubbed throttle inside but has not helped. should i check the throtle body for any debris that would cause it to stick.
Old 01-08-2010, 12:16 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Yeah, pull the tube off of the throttle body & check for sludge buildup around the throttle plate.
Using synthetic engine oil helps prevent the sludge.
Old 01-08-2010, 03:08 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
gasman6674 is gaining momentum as a positive member of FTE.
Wife's 05 v6 use to stick when it was cold, Dealer had to lube throttle cable, Problem went away and has not come back for 60000 miles
regards
Old 01-16-2010, 06:59 PM
tekrsq tekrsq is offline
tekrsq is starting off with a positive reputation.
My wife's 06 4cyl is doing the same thing. I've tried to figure out why for almost a month and can't find it. The good thing about it is it goes away after about 5 minutes, so this makes her FINALLY let the vehicle warm up a couple of minutes before she hits the road. Otherwise, it's start the truck, and hit the road.
Old 01-17-2010, 11:32 AM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Nitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant future
I believe there was a recall on earlier models. My '04 had to go back for this same issue. No issue like this on the hybrids - they are fly-by-wire.
87 XLT - could you explain how synthetic oil would prevent throttle body sludge....I'm not following.
Old 01-17-2010, 12:36 PM
I used to wonder how a TB would sludge up since only clean filtered air runs thru it.
Asked a mechanic and according to him when a hot engine is shut off oil fumes from the crankcase come up thru open intake valves. Theres less fumes from synthetic.
Old 02-14-2010, 09:33 AM
eberpimp69 eberpimp69 is offline
eberpimp69 is starting off with a positive reputation.
Yup that how my wife drives. start, drive and she has a heavy foot. gotta love them.
Quote:
Old 10-18-2013, 10:31 PM
Donzi Dude Donzi Dude is offline
Donzi Dude is starting off with a positive reputation.
Now my daughters 05 four cylinder escape is doing this
Any news on another recall for ford to fix their gas peddle problems
Old 10-18-2013, 11:05 PM
scott91370 scott91370 is offline
scott91370 is gaining momentum as a positive member of FTE.scott91370 is gaining momentum as a positive member of FTE.
I thought the recall was only on the v6.
Old 10-19-2013, 10:27 AM
Quote:
It would appear that the other ones are bad also
Old 10-19-2013, 11:18 AM
They may be sticky but it's not due to the recall. It was only up to 2004 and only the V6. It was a defect in spacing on the engine cover. It actually happened to me last year after owning it for over 250k miles. I put the throttle down all the way to merge onto the highway and it stayed. I pulled over and could feel it under the cover. I took the cover off and it's been in my garage since.
But you can look up recalls here:
FORD Recalls
Sticking Throttle tdimatteo Escape & Escape Hybrid 1 04-07-2015 01:22 AM
Throttle sticks on my 1989 F150 V8 texan 1987 - 1996 F150 & Larger F-Series Trucks 8 10-13-2014 06:59 PM
Sticking Throttle Repair makuloco2000 Escape & Escape Hybrid 0 12-26-2013 10:32 AM
Throttle body spacer for Escape? seamonkey49 Escape & Escape Hybrid 1 04-30-2005 03:26 PM
throttle sticking tw Expedition & Navigator 7 01-20-2003 03:34 PM
Tags
2002, 2005, 2008, cable, escape, ford, issue, maintenance, plate, recall, replacement, stick, sticking, throttle, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
