2005 Expedition Second Spark Plug Change - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 01-08-2010, 10:03 AM
ehaiss ehaiss is offline
ehaiss is starting off with a positive reputation.
As some of you know, I have already had the spark plugs changed on my 2005 Expedition with the 5.4L 3V that is imfamous for them sticking in the head. The dealer did the change and told me they have put high temperature antisieze on the replacements.
The replacement was done at around 65,000 miles, and I know have 93,000 on it, I am thinking about changing them again, to avoid the $2,000 bill it cost me the first time.
Does anyone know how easy the second replacement is? I know the plugs are 100,000 mile plugs, but I want to avoid them locking in again. Maybe I can get by with pulling the plugs, and refresshing the anti sieze. Any thoughts?
Old 01-08-2010, 11:18 AM
97ExpGuy 97ExpGuy is offline
97ExpGuy is gaining momentum as a positive member of FTE.
Here's your answer:
http://www.ford-trucks.com/forums/91...ml#post8337067
Also look at this:
http://www.ford-trucks.com/forums/90...ml#post8219650
Additional Info:
http://www.ford-trucks.com/forums/71...ose-plugs.html
If you search "spark plug" in the '2004 - 2008 F-150' forum you will find a lot of answers to your questions.
So far it looks that maybe leaving the plugs in the head longer will run the chance of them becoming weaker but others say leave them in till they are due. My advice would be to follow the advice of the three posts above and take your time.
Old 01-08-2010, 11:33 AM
fordtech08's Avatar
fordtech08 fordtech08 is offline
fordtech08 is gaining momentum as a positive member of FTE.
I think your wasting your money
Old 01-08-2010, 02:29 PM
Thanks '97ExpGuy. Interesting reading.
I already went through the pain of the initial change. I broke the first two I tried (using the TSB wethod), then took it to the dealer, where he broke 5 of the remaining 6. 7 of 8 would not come out cleanly. They pulled the body off the chasis to remove them, hence the $2,000 bill . . .
I am wondering if anyone knows if the anti-sieze works to keep them from siezing? With 30k+ on this set, I want to make sure it really fixed the issue.
Old 01-08-2010, 03:02 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
That's the job of anti-sieze. The unknown vaiable is if they really used it or not. BTW, why are you changing plugs at all? You're not supposed to change them until 100K miles and here you're ready to install a second set in less than 100K.
Old 01-08-2010, 04:38 PM
fordtech08's Avatar
I have yet to see a body come off to take plugs out
Old 01-08-2010, 09:11 PM
Why change the plugs?
alloro, good question. I read about the issue on the forum, and thought I would head it off at the pass by trying to change them at 60k miles. I broke the first one, then the second, and the rest is history. Having lived through that experience I don't want it to happen again.
fordtech08, I know it seems odd. The tech told me the tool he has would not fit under the cowl section, and it was easier to remove the body than the heads. Not sure. He did give me the plugs back and they were a mess. It sounds like the new removal tool is a better design.
Maybe I will try to pull the first one or two, and if they come out smoothly, I will leave well enough alone.
Old 01-08-2010, 09:49 PM
You do realize that it's the other 6 or 7 that will end up being the problem down the road.
Old 01-08-2010, 11:41 PM
pgonza2723 pgonza2723 is offline
pgonza2723 is starting off with a positive reputation.
unless crap plugs went into the truck the second time around are crap I wouldn't worry about it.
V10 - Replace Plugs, Coil Boots and PCV Valve - How Often? wcohalloran Modular V10 (6.8l) 6 04-02-2014 05:56 PM
97 Aerostar Check Engine Light On aerohiwaystar Aerostar 36 06-01-2013 10:28 AM
('07) 5.4l Ford Triton 3-Valve Stumbling Under Load *Solution* SS_Autowerks Expedition & Navigator 3 03-11-2013 05:04 AM
Spark plugs hard to remove on 5.4L pholahan Expedition & Navigator 7 02-15-2013 09:04 PM
Spark plug replacement? Gray Ghost WI Expedition & Navigator 8 02-10-2010 09:56 AM
Tags
2003, 2005, 3v, 54, change, changing, expedition, expedtion, ford, plug, plugs, removal, replacement, spark, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
