2002 f250 seat into a 2003 f150
1st i apologize if this ? has already been discussed.
Wondering if the seats (Front and Rear) out of a 2002 f250 will fit in a 2003 f150 super cab. Their power, leather, heated etc. i know i would have to wire the power part of it in. Just worried about bolt up.
Thanks
Thanks
Welcome to our world....While Im not familiar with your specific model,I can tell you that I bought a 60/40 split bench seat for my old 97 F-150XL before checking to see if the bolt patterns were the same.The new seat was cheap,and I figured since the truck was older,if it didnt bolt up,Id just "make it happen" somehow.
I pulled the old seat out,and the floor mat...The previous owner had installed captains chairs with center console out of a Lariat,and they were shot...anyway...to the point here....All the outside bolt holes lined up perfectly,and the inner holes(in the cab) had rubber plugs...pulled them out and the new seat was a dead-on match.
I think youll be good as far as the mounting is concerned,and as far as the wiring,as long as you know what your doing,and use the appropriate gauge wire you should be good to go.
Again welcome to the forum.....
Lori Treadaway
03-05-2014 03:09 PM
