ATE Brake Fluid - Ford Truck Enthusiasts Forums
ATE Brake Fluid
Old 01-08-2010, 07:43 AM
koski19 koski19 is offline
koski19 is starting off with a positive reputation.
ATE Brake Fluid
Which ATE Brake fluid would be best for our trucks. Thinking of performing a flush with my spring maintenance. Opinions anyone?
Thanks
jeff
Old 01-08-2010, 08:25 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Dot 4 is the best.
Old 01-08-2010, 09:57 AM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
Hey Jeff. I've been using this stuff for years. Alternate between the yellow and blue to see when each flush is complete.
Discount Super Blue Brake Fluid / ATE TYP 200 / SuperBlue - RACEShopper.com
Old 01-08-2010, 11:58 AM
Thanks for the replies. I'll be ordering the Blue fluid.
Jeff
Old 01-08-2010, 02:57 PM
Fat Diesel's Avatar
Here's a thread I started to show the power bleeder for our trucks. Others really like the speed bleeder valves.
http://www.ford-trucks.com/forums/52...with-pics.html
Old 01-08-2010, 03:01 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
I flushed mine with Valvoline DOT 3/4 Synthetic. Good to go, and it was the last fluid I needed to convert to syn. Now everything in mine is syn.
Old 01-08-2010, 05:38 PM
Andy,
You got a part number on that pressure bleeder? How many liters of fluid did you use?
Jeff
Old 01-08-2010, 07:36 PM
Fat Diesel's Avatar
As I recall you need to pull off your master cyl cap and see if it's a 2 prong or a 3 prong cap. Then you talk to the folks at Motive Products and they make sure you get the right one.
Old 01-08-2010, 09:38 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
I'm pretty sure all of our 7.3's are three prong.
My '99 Lightning is, my '00 Excursion is, my '02 F250 is, and my '03 F150 is. I think my daughters '03 Escape is too, but I haven't checked.
I just flushed my F250 and my Excursion and I used two-32oz bottles on my truck, but I used three-32oz bottles on my Excursion. I used more on the Ex because I was busy doing other maintenance items while flushing the Ex. The F250 I was only doing the flush, nothing else.
Stewart
Old 01-08-2010, 09:46 PM
Izzy351's Avatar
Yep -- two will do it. I used less than two for mine. Pressure bled with homemade bleeder:
Old 01-08-2010, 09:49 PM
Stewart_H's Avatar
Quote:
Yeah, I actually used less than two-32oz bottles too. There was probably 4 or 5 ounces left from the second bottle. But it's not like you can save it on the shelf. Once a bottle of brake fluid is opened, it starts to absorb water so I was always taught to throw away any remaining fluid after a flush.
Stewart
Old 01-08-2010, 10:58 PM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
WA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to all
Quote:
Stewart
X2 Stewart!
09 6.4l power steering noise ATE88 1999 to 2016 Super Duty 0 09-15-2015 10:53 AM
Mice ate my wiring and other foam parts! mrford49 2009 - 2014 F150 37 11-20-2014 02:59 PM
Brake Fluid (DOT 3) WK15 6.7L Power Stroke Diesel 2 03-28-2012 11:40 PM
1995 F350 Brake Bleeding Problem 1Tonn 1987 - 1996 F150 & Larger F-Series Trucks 18 05-23-2011 09:23 AM
Brake bleeding ? Nice Work Truck 6.0L Power Stroke Diesel 16 10-25-2009 11:44 PM
Tags
ate, bleeder, blue, bluish, brake, fluid, ford, fort, hunter, lightning, psd, truck, trucks, worth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
