P1867 code and 1165 codes both on 2005 Expedtion - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-07-2010, 11:55 PM
FIRERACER FIRERACER is offline
FIRERACER is starting off with a positive reputation.
Hello, i have both an 1867 code t-case contact plate circuit on and a rr wheel sensor 1165. This is in an 2005 Expedition with AWD 4X4HI./LOW. The truck will not engage four wheel drive at all. Just spins both rear wheels. Should i assume it is the shift motor? Do the wheel sensor ABS light on have anything to do with this? I did replace the RR wheel sensor but the code with not clear.
What testing can i do on the tranfer case shift motor and associated circuits? Thankyou.
Old 01-08-2010, 07:33 AM
Any information on this? its snowing again.
Old 01-08-2010, 02:12 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Old 08-28-2013, 10:30 AM
RIGHT REAR WHEEL SENSOR CODE 1165
Working on the 2005 Expedition again. We still have right rear wheel sensor code 1165. Have replace the Hub and sensor. The code will not clear. The wiring is all good up to the harness on ABS. Fuses are all good. Could it be the unit itself? It will not activate with the scanner.
Old 08-29-2013, 09:23 AM
Quote:
Yes, it could be the ABS unit.
Rear wheel speed sensor check/replace nebechanezer 2009 - 2014 F150 5 01-09-2014 11:27 AM
I hope i am posting in the right location roger.lees51 1999 - 2003 7.3L Power Stroke Diesel 25 06-24-2012 10:18 AM
F 250 problems roger.lees51 1999 to 2016 Super Duty 4 06-03-2012 03:03 PM
No 4x4 with codes 89LX306 1999 - 2003 7.3L Power Stroke Diesel 12 12-14-2011 02:56 PM
Help! many codes where do I start? xlsportrider Electrical Systems/Wiring 6 06-13-2011 10:17 AM
Tags
01, 2000, 2006, code, codes, contact, dtc, expedition, explorer, f150, f250, ford, p1867, plate, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
