Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > North Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
  #1 (permalink)
Old 01-07-2010, 07:06 PM
truckerboy truckerboy is offline
1986 Ford F-250
truckerboy is starting off with a positive reputation.
oil and plug problem
ok, i got a 81 f100 with a 300 engine. There is oil on the plugs, and it is fileing them out. Someone tod me that it may be the valve covers, but smeone else sad it is the rings. can any of yll straiten this out.
  #2 (permalink)
Old 01-09-2010, 05:22 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Almost Normal
1995 Ford F-150
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
check the compression, see how even they work out, then do a leak down test to see if the compression holds. I susspect worn, or broken rings
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Quote:
Originally Posted by 67nukeford View Post
Charlie, don't make me come there and kill you...
"If more sane people were armed, the crazy people would get off fewer shots."
  #3 (permalink)
Old 01-09-2010, 05:37 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
Garage is empty, add now
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
No way a valve cover leak will foul a plug. Do a leakdown test on ALL cylinders and see what your have. You prob. have worn rings.
__________________
-Scott
SOLD 2-28-11.....
'06 F250 CC/SB PSD. 2'' lift, Bilstein 5100's, Dual stabilizers, 20'' Harley wheels, 35-12.50 MT ATZ's, 08 Mirrors, ARP studs, EGR delete, 4'' MBRP, X3 with custom tunes, Full gauges, scangauge II, Coolant filter, Red top Optimas, DC 185a alt,
  #4 (permalink)
Old 01-09-2010, 07:47 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
MAKO314 has a good reputation on FTE.MAKO314 has a good reputation on FTE.
oil fouled plugs is usualy a sign of worn valve guides or valve seals. broken or worn rings can do it but alot less common.
__________________
Ashley
2000 F250 Destroked "Frankinstien" CR 5.9 Cummins 631 HP 1389 lbtq
2003 explorer limited AWD V8
1990 7-UP mustang 5.0
Tags
2003, foul, mountaineer, oil, plugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
