If you don't mind the polka dot look you can go with an 87+ cowl to keep out the leaves. Or do like I'm going to do and glue a black metal mesh below your current cowl.
I'm going for the stock look and plan on the mesh idea.
LOL! I think you MAY have found a problem or three. Two twisted off bolts on the timing cover and a timing chain that is badly worn. Yup, that's gonna need some attention. Good luck on the bolts. Those can be a bear.
You can try penetrating oil, then heat, then penetrating oil, etc on the one that protrudes. It probably won't come loose but its worth a try. However, on the other you'll have to drill it and try an eazy-out. But it'll take heat, penetrating oil, etc on it as well. And by heat I mean a LOT.
for bolts broken off with some of the threaded section exposed i use the craftsman bolt out . Saved my bacon when I snapped a bolt to my thermostat housing .
So last Monday I went down to my local machine shop and placed an order for a 351w HO roller motor. Week later she was ready for pick up. Engine was bored .30. Friday i'll be picking up some black engine paint.
For the intake I went with the Elderbrock Performer (non egr), and the carb is the Summit M2008, 600 cfm. Gasket and the silicone gasket maker will arrive tomorrow. Goal is to paint the engine, and install the intake this weekend.
