GM NV 4500 trans behind a 390. - Ford Truck Enthusiasts Forums
Old 01-07-2010, 06:27 PM
Cobra Highboy Cobra Highboy is offline
Cobra Highboy is starting off with a positive reputation.
I have done a lot of searching but all the info I find is people putting the 5 speed transmissions behind 460, 351m, and 400.
The Truck Info: 74 F250 4x4 390FE, NP435 4spd, NP 205 Transfer case.
I can get a GM NV 4500 5spd for free, so my question is... Has any one put a 5spd trans behind a 390 or is everyone converting to 460? I think my 390 has more power than a 460 and would just like to put a 5 spd behind it. any help is greatly appreciated.
Old 01-07-2010, 09:49 PM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
Check with advance adapters
Old 01-08-2010, 03:25 PM
I couldn't even find a conversion kit for a big block ford at all on advance adaptors.
Old 01-08-2010, 03:31 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
These fellers sell the adaptor, lots of info right here:
High Impact - NV4500 5spd
Old 01-08-2010, 09:17 PM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
Price? LOL :)
I found two so far, one was $825 and the other $850! :/
A guy could buy a parts truck with a 460 and ZF for that kind of money.
BTDT and it was $500 as a matter of fact and had a 10.25" LSD too. ;)
Alvin in AZ
ps- check this out...
http://quad4x4.com/NV4500%205th%20Ge...0Solutions.htm
Old 01-08-2010, 09:52 PM
sc00ter sc00ter is offline
sc00ter is starting off with a positive reputation.
Advance adapters does sell one that should work- there's an article about the swap on a 390 on htis site. they list it as being for a sbf. But if you use it with a 390 bell housing, I don't see why it wouldn't work. I've never done the swap, so that's all I know. I think they specifiy that the trans be from a gas powered dodge- prolly has something to do with input shaft length and spline count. They also make an adapter to put a ford type np205 behind the nv4500.
Old 01-09-2010, 02:13 PM
Thanks guys this is great info.
Old 01-10-2010, 11:23 AM
lurch460's Avatar
lurch460 lurch460 is offline
lurch460 is gaining momentum as a positive member of FTE.lurch460 is gaining momentum as a positive member of FTE.
Advance adapters is the place to go. When I went to SEMA a couple years ago I talked to them about this, they said the dodge gas powered is the tranny to get. The books they gave me on this said that the gm can be usable but the input shaft has to be convereted to dodge. Its the length and spline count that matter. There is a guy on here that has done it and its a clean swap, think he is in the bumpside furom tho, 71 highboy if i remember correctly.
Old 01-10-2010, 01:06 PM
73FordF100's Avatar
73FordF100 73FordF100 is offline
73FordF100 is starting off with a positive reputation.
There is a guy in the bumpside section who did this but it wasn't a 4x4. Here is a link to how he did it:
Installing the NV4500 Overdrive Transmission .: Articles
Old 01-10-2010, 09:01 PM
BarryB's BarryB's is offline
BarryB's is starting off with a positive reputation.
Quote:
Yes it has to do with input and output shaft. The NV4500HD from a dodge diesel has a bigger output shaft. The GM nv4500 is the same as the dodge gas trans. I went thru this finding parts for my NV4500HD that is in a Dodge Ram diesel I used to own.
Looking for a better trans 264WSM Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 08-05-2014 11:21 AM
79 f250/cummins swap questions F-250 WARHORSE Engine Swaps 3 10-10-2013 11:31 AM
1975 F250 5Spd Transmission Conversion 76'Highboy 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-17-2010 01:00 AM
NV4500 and NP205 ?? jimlj Clutch, Transmission, Differential, Axle & Transfer Case 2 10-06-2009 11:20 AM
Nv4500 biz4two Clutch, Transmission, Differential, Axle & Transfer Case 7 01-19-2004 01:35 AM
Tags
2010, 390, 390fe, 4500, 5spd, biy, fe, ford, high, highboy, np205, nv4500, swap, trans, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
