Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
DT 466 Transplant.
Old 01-07-2010, 05:24 PM
UGA33's Avatar
UGA33
UGA33 is offline
DT 466 Transplant.
My buddy has decided to fund a project that is sure to be a great one if we are able to get it completed. We have decided to drop a 94 P-Pumped Dt 466 into a 77 bodied Ford truck and then plop that onto a 2004 F350 frame. Here are the only two pics of the project so far.
More to come once the motor arrives next week.
Old 01-08-2010, 02:51 AM
rebocardo's Avatar
rebocardo
rebocardo is offline
Will the F-350 frame hold up to the weight of the DT466? I would think just the engine is pushing 1800 pounds.
Old 01-08-2010, 08:19 AM
UGA33's Avatar
UGA33
UGA33 is offline
After a little reinforcement up front it will be fine. Motor weighs just shy of 1500lbs.
Old 01-23-2010, 10:57 PM
UGA33's Avatar
UGA33
UGA33 is offline
Motor arrived last Monday. We were able to get the 77 stripped down to the frame today and all we have to do now is find an 01+ 3/4 or 1 ton frame!
Old 01-25-2010, 02:20 PM
ghunt's Avatar
ghunt
ghunt is offline
So how well does that engine fit in the engine bay?
And...why only an '01+ frame?
Old 01-25-2010, 06:45 PM
UGA33's Avatar
UGA33
UGA33 is offline
The firewall will need a lot of fabrication for the motor to fit. The newer frames will also keep us from having to mount the steering gear box on the outside of the frame due to the width of the motor. They also have better brake systems and such. The reason for the 01 is for the D60 front end.
Old 01-26-2010, 12:39 AM
parkland's Avatar
parkland
parkland is offline
This is great !!!!
I am planning on buying a 99-06 crew cab superduty and plunking one in.
The only problem is finding drivetrain stuff that will handle the power if you start putting in injectors etc.
I'm thinking the stock d60 should be alright, but extra springs in the front, and a lift too, just to make it fit.
My plan is to use a 6sp manual tranny with the 466, and worry about a transfer case after.....have to keep the HP lower to use anything but pulling parts...
Are you using this for driving around, or sled pulling?
Look out dodge boys.
Old 01-26-2010, 04:06 PM
UGA33's Avatar
UGA33
UGA33 is offline
It is going to be my friend's daily driver which he plans to do everything with. What got this entire project going was seeing too many Cummins conversions.
Old 01-28-2010, 06:18 AM
torkum's Avatar
torkum
torkum is offline
Great project! We had a pre '78 Bronco show up at our chapter meet in Knoxville last week with a PSD in it. The fit was tight in the front but overall looked factory.
Old 01-28-2010, 07:31 PM
nevrenufhp's Avatar
nevrenufhp
nevrenufhp is offline
That's one of the main reasons I'm tackling the Ford 6.6 in my 67. So many 6BT swaps, and it's cooler to have an all Ford drive train.
Old 01-31-2010, 01:15 PM
Customcab's Avatar
Customcab
Customcab is offline
Hope putting a Dt466 project together that; this becomes a tech article build.
For us dreamers!!!!!
Mitch
GreatNorthWoods
21
10-10-2012 09:46 AM
cdrmotorsports
1999 to 2016 Super Duty
22
09-03-2010 12:02 PM
Brown Falcon
07-12-2009 08:50 AM
460429_freak
Missouri Chapter
05-14-2009 01:56 PM
morgan867
2009 - 2014 F150
56
01-01-2009 02:59 PM
Quick Reply: DT 466 Transplant.
