You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
My buddy has decided to fund a project that is sure to be a great one if we are able to get it completed. We have decided to drop a 94 P-Pumped Dt 466 into a 77 bodied Ford truck and then plop that onto a 2004 F350 frame. Here are the only two pics of the project so far.
The firewall will need a lot of fabrication for the motor to fit. The newer frames will also keep us from having to mount the steering gear box on the outside of the frame due to the width of the motor. They also have better brake systems and such. The reason for the 01 is for the D60 front end.
I am planning on buying a 99-06 crew cab superduty and plunking one in.
The only problem is finding drivetrain stuff that will handle the power if you start putting in injectors etc.
I'm thinking the stock d60 should be alright, but extra springs in the front, and a lift too, just to make it fit.
My plan is to use a 6sp manual tranny with the 466, and worry about a transfer case after.....have to keep the HP lower to use anything but pulling parts...
Are you using this for driving around, or sled pulling?
Look out dodge boys.
__________________
Such a cool little toy, for what it costs :
It is going to be my friend's daily driver which he plans to do everything with. What got this entire project going was seeing too many Cummins conversions.
Great project! We had a pre '78 Bronco show up at our chapter meet in Knoxville last week with a PSD in it. The fit was tight in the front but overall looked factory.
That's one of the main reasons I'm tackling the Ford 6.6 in my 67. So many 6BT swaps, and it's cooler to have an all Ford drive train.
__________________
Dale. turn up diesel fuel rate site of mine
67 F100, 300, 4spd, Offy 'C', Edelbrock 500, 274*/.518" cam, heddder.
82 Mercedes 300SD, mods to come.
