Seafoam or other engine treatments
I did a 50/50 mix in my 6.9 last year. Put 5 quarts of Automatic transmission fluid in it, and 5 quarts of motor oil and go for a nice long hard ride.
Drive it like you stoll it at times.
When you get back, drop the oil and replace filter.
If you think the engine is still dirty inside, repeat the process again at your next oil change.
When I did it to the 6.9, I notice a small differents in power and gained abit of oil pressure.
I don't know if it needs it or not or if there's any benefit to it. I'm just asking. I thought this would be a good time to do it if I'm going to.
WARNING: If you are going to use Sea Foam do some shopping for price. I just paid $60 for a gallon at Advanced Auto last week. Yesterday I bought a gallon of Sea Foam at TSC (Tractor Supply Company) for $40 and it was NOT on sale. This gets the cost per 16 oz down to $5.
With a diesel you DO NOT want to put it in the intake because it will RUN AWAY on you so only put it in fuel tank. I will put it in the crank case for the last 1-3 hours before an oil change but would not if it was going to be working hard like climbing a mountain.
In the gas stuff I use in in tank, intake and crankcase. Yesterday we stock piled gas for the generator and it all got Sea Foam to stablize the gas and WM 2 cycle TCW3 just for the heck of it. The 2 cycle oil really makes the diesel more quite at idle in our case.
I moved from Sta-Bil to Sea Foam. A local shop told me he would not look at my car until I used a couple tanks treated with Sea Foam. The poor running went away as the shop owner expected so i have used Sea Foam ever since.
After 50 years of being on the market and more and more people using it today many must have had a positive experience with Sea Foam as well. The MH has a 60 gallon tank and the F700 a 50 gallon tank so I put about 1/2 gallon in each this time of the year.
i will warn you from experience.if your going to use sea-foam in your oil and you have a small oil leak after you use the seafoam i will be a bigger oil leak.yes its a good cleaner but i wont use it in the oil ever again.it took me forever to track all the leaks and get them stopped
guys....
If you have leaks anything you use to clean it will make leaks worse. Most likely build up of crap will be dislodged and create a bigger leak. It just makes sense.
No one cleaner will be that much worse than the other in terms of making leaks worse (unless the cleaning agent isnt working!!!)
Good Luck to the OP.....
Thad
Thad
guys....
Thad
Thad
Seafoam must be a regional thing as I had never heard of it until I started messing with a boat forum a couple years ago. and for several years I had every snakeoil salesman in the world come to the shop on regular schedules, I thought.
Never seen it in a parts house or tractor supply never heard of it at all.
on
a properly maintained engine will remain clean inside.change the oil and filter regularly and you wont have sludge in your engine.
the old ATF in the oil before the change,is not needed if you maintain it.beside this,it doesn't have the lubricity that oil has,so while your running it,even if its a small amount of time,you can hurt the bearings.
most used 1 quart.over that,and your asking for trouble.
there are more modern ways.the best way,is to simply maintain the engine properly in the first place.my 2 pennies.
