1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Intermittent P0181 Code - 03 Expedition 4.6L
Old 01-06-2010, 10:57 PM
randinow's Avatar
randinow
randinow is offline
I have been getting the Check Engine light and the code reader says it is P0181, I have tried to read up on this issue but I don't believe my truck has a Fuel Temp Sensor. This code does seem to come with less than 1/4 of a tank of gas, but not always, I have read that that may indicate my fuel pump. Any ideas???
A bit of history.... ever since I have had this Expy, about 4 years now, it has had a hesitant start, it will take a while to finally crank, the engine turns then it will finally crank...about 3 years ago I took it to the Ford dealership and they said I needed a new fuel pump then, I said I would wait, and got a 2nd opinion who didn't seem to think their was a problem with the fuel pump, so I let it ride, still does the same thing no worse no better, but it has always eventually cranked...this code makes me think maybe the fuel pump is getting worse....
Old 01-07-2010, 10:03 AM
1whoseeks's Avatar
1whoseeks
1whoseeks is offline
Might be the fuel filter as well. This may over work the pump causing a rise in heat. I like to try the simplest and least expensive thing first. If you have not changed the filter then try that first. If the problem still exists a good mechanic should be able to see if you are getting the needed fuel pressure to the injectors as well.
Old 01-07-2010, 10:51 AM
fordtech08's Avatar
fordtech08
fordtech08 is offline
it sounds like the pump, it's losing pressure while it sits, next time instead of cranking it just turn the key to on about 4 times for a couple of seconds to allow the lines to reprime
that way your not running the starter for a long time
Old 01-07-2010, 08:24 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
Ditto on the pump. The fuel in the tank acts like a heat sink for the pump. When you're down to a 1/4 tank, the pump is not immersed in the fuel so it runs hotter, hence the code.
Old 01-07-2010, 09:55 PM
randinow's Avatar
randinow
randinow is offline
That's sorta what I was thinking about the pump, so a cheap fix would be to not let it get that low? LOL, I have dealt with the hard starts for 3 years so I am not terribly bothered by that, but makes me think the pump is going down hill if it is throwing that code now...
Old 01-08-2010, 01:07 PM
alloro's Avatar
alloro
alloro is offline
If the issue is getting worse you could be facing a pump failure in the near future. It will of course happen at the most inconvenient time.
Old 01-08-2010, 11:09 PM
randinow's Avatar
randinow
randinow is offline
yep that's Murphy's law, and my luck....
Adam0181
2004 - 2008 F150
08-13-2016 11:09 AM
Adam0181
2004 - 2008 F150
07-13-2016 12:05 PM
53crewchief
1999 to 2016 Super Duty
09-09-2012 01:20 PM
JBronco
1978 - 1996 Big Bronco
09-27-2006 06:04 PM
msanders
02-25-2005 03:26 PM
Quick Reply: Intermittent P0181 Code - 03 Expedition 4.6L
