clutch/trans noise?
clutch/trans noise?
1989 f150 2wd 302 mazda 5spd
ive been hearing a noise coming from my tranny/clutch it sounds like running water sometimes it stops when i push the clutch pedal sometimes its always making the noise- the noise doesnt accel/decel it is just there. what is it?
i appreciate any info you can offer thanks for reading this
Does sound like input shaft bearing.
Mine does it. 89 4.9 M5R2
If I push the clutch in and put it in gear - as long as the truck is standing still - there is no noise.
Once the truck starts to move (even with the clutch in) or I let off on clutch the sound comes back.
Have noticed that the higher the gear the less noise it makes.
I'm just living with it.
/Ricache
/Ricache
