What to do with my Flatty
Alright i am trying to get some think done, while i am watching my Hawkeyes kick some butt in the Orange Bowl.
I am not sure what to do with my 53 flatty v8. As far as i know it have 33,000 original miles. we have owned it since 92, but it has sat for longer than that in south dakota. He has a guy do a little work on it have he got it running in the 90s.
My question is how far should i take this thing apart. As of right now I am not doing any major upgrades just stock( upgrades will come once i can actually enjoy driving the truck for a while)
Why take it apart at all. Pull the plugs and clean them off, charge the battery, drain the gas tank and put some new gas in it, change the oil and radiator coolant and try and fire it up. If it's not stuck, chances are with a minimum amount of work it will start right up - you might need a touch of starter fluid for the first few tries.
There are many stories of flatties sitting for long periods of time that with a "dust off" ran like tops!
That's right Julie, I had a local farmer give me an old 51 F-3 that was owned by a deceased friend of his dad and it had been sitting in the same spot on the farm for over 16 years. I gave him $20 for helping me load it.
got it home and changed the oil. thing runs great and has between 122-130 PSI on all cylinders... I would just drive it. Once apart one thing leads to another- before you know it you'll have a couple grand sunk into it, and thats just basic stock rebuild. let us know how it turns out.
Edit: I see, at least pull the intake manifold and inspect valves, guides etc. make sure there is no mice nest's in there too. Clean it up and make a quick test stand to run it on and make sure all is well prior to reinstallation.
It's a false economy to skip a teardown on a 57-yr-old engine. First off, do you have real records that it has 33k miles? Unless it was a farm truck that never left the farm, I'd really be surprised. If it was, those could be some mighty hard 33k miles. All the gaskets are suspect, the block is likely rusty inside (antifreeze is only good for 5 yrs, whether it runs or not, in terms of corrosion protection).
For the cost of a gasket set, you can take off the heads and intake, and see how much sludge there is, and remove all the carbon. See if the block has cracks. Pull a the main bearing caps and the rods, mike them, look at the journals... check the oil pump, clean out the oil pan... thoroughly clean out the cooling passages and check out the water pumps....
I did this and more, took out all the pistons and valves, cleaned it all up. I know what is good and what it will need in another 20k miles. Total cost was $100 for a gasket set and 3 cans of Ford Blue engine enamel.
