block heater location? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-05-2010, 07:05 PM
skeeterguy34 skeeterguy34 is offline
skeeterguy34 is starting off with a positive reputation.
hey guys. My dad has a 97 f250 and the block heater has stopped workin. Is there any common reasons these go out? Also where exactly are they located and are they hard to change out? thanks guys
Old 01-05-2010, 07:08 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
it's above the oil filter it's not bad to change you need to check the power cord
Old 01-05-2010, 07:15 PM
dougbrown's Avatar
dougbrown dougbrown is offline
dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.
Does the block heater heat the oil or anitfreeze?
Old 01-05-2010, 07:31 PM
fordpride's Avatar
antifreeze
Old 01-05-2010, 07:34 PM
dougbrown's Avatar
Quote:
Originally Posted by fordpride View Post
antifreeze
Thank you.
Old 01-05-2010, 09:52 PM
yoslick's Avatar
yoslick yoslick is offline
yoslick is starting off with a positive reputation.
+1 check the cord, bet it's rotted
Old 01-06-2010, 05:33 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
I have had bad neutrals on the extension cord before. Also ohm out the coil it should be about 15 ohms.
Install block heater on 6.0 diesel help L121andrew24 1999 to 2016 Super Duty 11 01-07-2016 06:43 PM
Block Heater Location? raygant 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-25-2012 11:40 PM
block heater location mongo12 1994.5 - 1997 7.3L Power Stroke Diesel 13 12-14-2009 07:31 PM
Engine Block Heater F550 daveyo 1999 to 2016 Super Duty 2 03-03-2008 12:10 AM
location of block heater? gameboynws 6.0L Power Stroke Diesel 4 01-10-2004 05:52 PM
Tags
1997, 1999, 73, 97, 99, block, diesel, f150, f250, f350, ford, heater, located, location, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
