Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 01-05-2010, 04:50 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.
EBPV Delete Plug? Can I make my own?
Cash is really tight, and I'm hoping someone can help me with this issue.
I've searched through FTE and cannot find any reference to how the infamous EBPV Delete Plug is constructed. I know how to make my own AIH code delete wire (using a 470 ohm 1 watt resistor), and I want to make my own EBPV delete plug as well but don't have the nitty gritty details. Several comapnies make and sell them (Pure Diesel Power and Dfuser, I know for sure), but I don't want to pay $40 plus S&H right now.
I already have the new EBPV sensor to replace my currently malfunctining one, but would rather sell the brand new sensor and simply delete the need for one altogether and simultaneously eliminate the soft coding as well.
I've even been tempted to pruchase a plug , tear it down, and then share what I find out with everyone here, but I can't justify throwing the money away by tearing it apart to find out everything that's built into it.
Like always, thanks in advance for any and all input/insight.
__________________
Pete (F250_) -- PAA#19
'02 F250 PSD, CC, SB, XLT, 2WD: 231K miles
Basic, low cost, not really performance enhancing mods.
'03 Excursion PSD, 2WD, 165K miles - Stock.
http://guzzle.rbmicro.com/7pt3/Mods.html
  #2 (permalink)
Old 01-05-2010, 05:02 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1996 Ford F-350
My Garage
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
I'm not sure I understand the need for a plug... just unplug the connector from the EBPV on the front of the pedestal and no more EBPV. What am I missing here Pete?
On edit- you want to clear the soft code? Just put the same 470ohm 1watt resistor across the 2 wires in the EBPV plug as you did for the AIH delete and it should eliminate the soft code.
__________________
Chase
PAA Member #2
97 F350 CCLB 4x4 PSD
96 F350 CCLB 4x4 PSD - totaled 4/17/11 and sorely missed
God speed PaysonPSD, you will be missed
ThumperTalk / All Things Moto! / Back Country Rebels / SAWS / BRC
  #3 (permalink)
Old 01-05-2010, 05:13 PM
tdpower's Avatar
tdpower tdpower is offline
2000 Ford F-250
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
http://www.ford-trucks.com/forums/85...unplugged.html
Here is a quote from Chase in this thread above. "All you need is a 1/2 watt 470 ohm resistor between the two wires on the EBPV plug. Easy sleazy. " Looks like he already replied but may of mix up the two.
  #4 (permalink)
Old 01-05-2010, 05:14 PM
F250_'s Avatar
2002 Ford F-250
Chase... that's what I was looking for... the resistor details for making the soft code eliminator connection. I wasn't sure if it would be the same for the EBPV as it is for the AIH. Thanks.
I knew that I could simply unplug the connector, but want to simultaneously eliminate the soft code issue as well.
Grant... that was the thread I had remembered seeing, but could not find it when I searched earlier. Thanks for the link.
__________________
  #5 (permalink)
Old 01-05-2010, 05:49 PM
1996 Ford F-350
My Garage
Quote:
No prob Pete, glad to help. I don't think 1/2watt or 1watt matters, I seem to remember... I believe it was Roland that used a 1/2w for the AIH delete and it burned up so he put in a 1w and it was fine. Sounds like you already have the 1w resistor so I'd just use it.
__________________
Chase
PAA Member #2
  #6 (permalink)
Old 01-05-2010, 05:59 PM
F250_'s Avatar
2002 Ford F-250
Quote:
Originally Posted by superduty4x4 View Post
... put the same 470ohm 1watt resistor across the 2 wires in the EBPV plug as you did for the AIH delete and it should eliminate the soft code.
There... fixed that for you, Chase... would hate for someone to get those engineering units backwards and then try to find such a resistor.
__________________
  #7 (permalink)
Old 01-05-2010, 06:30 PM
1996 Ford F-350
My Garage
Click the image to open in full size.
I have no idea what you are talking about, my post is correct...
__________________
Chase
PAA Member #2
  #8 (permalink)
Old 01-06-2010, 09:19 PM
F250_'s Avatar
2002 Ford F-250
Correct?
I looked for 20 minutes at Radio Shack this afternoon and could not find a 470 watt and 1/2 ohm resistor anywhere, but I DID find a 470 OHM and 1/2 WATT resistor!!
It's ALL good, though, Chase... I knew what you meant!
__________________
  #9 (permalink)
Old 01-06-2010, 10:44 PM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
Garage is empty, add now
mueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant future
Roland Mueck
That wasn't the AIH that burned up the resistor. I used a 47 ohm resistor in the wastegate solenoid plug and that's what burned up. I currently have a 470 ohm 1/2 watt resistor in each of the AIH, EBPV, and Wategate Solenoids' plugs as "code eliminators".
__________________
Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6 (live tuned), AFE II w/ Pete's Cover, GTP38R w/ Riffraff billet whl & 1.15, 6.0 Techni-cooler IC, Full Force SS Injectors, Stealth HPOP, Fluidampr, Melling M-208, Walbro FP, mueckster Reg Return & Bowl delete, 910 Springs, mueckster 4R100, 4" SS MBRP, 6.0 Trans Cooler, billet 710 cap, Truetrac rear
PAA Member #62
... From Rock to Rocket-- Thanks to the Brotherhood.
  #10 (permalink)
Old 01-07-2010, 09:48 AM
1996 Ford F-350
My Garage
Correct?
(shhhhhhh, don't tell anyone, but I edited my post to be correct. But I would like to see the look on someone's face when you ask for a 470w 1ohm resistor- please take pics )
Roland- blame my mistake on the fact that I'm employed by the US gov't. Sometimes we make up lies even if the truth is more interesting
__________________
Chase
PAA Member #2
Tags
2000, 73, aih, code, code eliminator, connector, delete, deleting, ebpv, eliminator, f250, ford, ohm, power, psd, resistor, strocke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
