What years had 16 inch wheels?
#31
#34
A little info on the split wheels. These were used to mount 6 or 8 ply tires. Back then tire mounting machines were not as good as the ones of today. With the air out of the tire, you could remove the split rim and slide the stiff tire off the wheel. I had done many a split rim duelly wheels and it has been many years ago but I can remember doing some like that as well. Back then they were known as widow makers. If the rim was not installed right, it would fly off as the pressure came up on the tire and take your arm off.
I am just getting started good on my 52 F1 and it has 15" wheels. By the time I am finished I want to come up with the 16" as I am going to stay stock all the way.
#35
#36
#37
Ilya - looks like a 16" x 4" was used on half tons between 1940 and 1946. Ford #01A-1015. There was also a 16" x 4" used by Merc for 40/41 model years, part #11A-1015. And by Zephyr for '39/'40. Part #06H-1015. These are all 5 lug x 5 1/2 circle.
Josh - There's been a gazillion different 15s available from 1939 on for the various makes and models. For purposes of our group, looks like '55 was the year a 15" x 5" was sourced on a F-100. Part #B5C 1015-A. Stu
If a specific '41 Mercury wheel (AFAIK, there wasn't one), the prefix would be 19M. Every 1946/48 Merc I've seen had 15" wheels, while the Ford's had 16's.
AFAIK, 1955 was the first year Ford offered 15" wheels on F100's...and...as standard equipment. 16's became as option (were available thru 1979).
#38
Hey thanks for the reply but I'm not sure if that's the same style of rims that would have come on a 66 Bronco.
I think you have an earlier version 16" wheel then a 66 model truck. I could be wrong seem to be a few different rims Ford offered. I would like if someone posted pictures of the different types.
1966/71 Bronco ~ as original: B4TZ-1007-C .. 16" x 5" Wheel-non Split Rim / Marked #75192 / Use with external ("outie") hubcap.
Other applications: 1954/71 F100.
In 1972, Ford replaced B4TZ-1007-C with D2TZ-1007-E = Applications: 1954/79 F100, 1966/79 Bronco / 1975/79 F150.
Originally Posted by 66 bronco roadster
What year was your Bronco? I'd guess 1966, but it could be 67-68 because it doesn't have side marker lamps and/or reflectors.
1968/69 Bronco's had reflectors, 1970/77's had lamps that lit up.
#39
#40
Welcome to the wonderful world (not!) of Ford updated part numbers.
Side marker lamps were mandated by the NHTSA for all vehicles beginning model year 1968 (began September 1967).
The reflectors for the Broncos really did start until the 69 model and like you said the side marker lights started in 70. Why the Bronco took longer then other Ford vehicles to get the new updates who knows??? I personally don't like the look of the side markers or the 69 reflectors it's one of the reasons why I like the 66-68 Broncos a little better.
Thanks Jeff
#41
If not introduced for Bronco's until 1969, why are the part numbers 1968 related?
C8TZ-13380-A Right Body Side / C8TZ-13380-B Left Body Side / C8TZ-13380-C Right Front Fender / C8TZ-13380-D Left Front Fender.
You're looking at these Bronco's 40 some years after the fact. It's almost impossible to find an 'un-cut' 1966/77 Bronco, and...
Bronco's have prolly had more parts swapped around than any other FoMoCo vehicles except Model A's, T's, '32/34 Fords and 1965/68 Mustangs.
#42
Side marker lights were mandated by the US Gov't for all 1968 foreign/domestic vehicles sold new in the US.
I don't have an answer for the C8TZ side marker light part number but they didn't show up until 1970 model. Who knows why??? Yes I think the early Bronco is one of Ford's biggest mutt, not only from used pieces and swaps but also right from the factory. It used stuff form the Mustang, Falcon, Econoline, and the F100 so tracking and finding so of NOS parts can be a bit tough a times.
#43
I don't know that much about the US mandate in 68 but I know for sure the side marker lights did not start until 1970! I understand mix and match Broncos thing (I have built a couple that way) and even cut Broncos still don't cut away the side marker area. Apparently most of the 68's did have the reflectors but I guess the very early production 68 didn't get them.
These were used on 1970/72 Bronco's (1973/77 are different), 1970/74 Econolines and on the rear only of 1970/72 F100/350 Stylesides & Flaresides.
And if you need part numbers to learn what is what and which is which, the 1965/72 and 1973/79 Ford Passenger Car Parts Catalogs are availabe on CD's from hipoparts.com.
Bronco parts are listed in these catalogs 1966/79, not in the truck catalogs.
77429highboy
06-03-2011 02:48 PM
gblaz123
05-14-2011 10:19 AM
L.TONY F350
07-26-2006 02:05 PM
