What years had 16 inch wheels? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-05-2011, 02:02 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Was mine, but someone vandalized it pretty bad (think shotgun), so it ended up being scrapped with the driveline being saved. Not sure I have a picture close up of the wheels, but I can take a look later.
  #32
Old 08-05-2011, 06:07 PM
66 bronco roadster 66 bronco roadster is offline
66 bronco roadster is starting off with a positive reputation.
What year was your bronco? If I would guess my first guess would be a 66 but it could be 67-68 to because it doesn't have side marker lights and/or reflectors.
Thanks Jeff
  #33
Old 08-05-2011, 06:10 PM
havi's Avatar
It was a 1966. Used to be the plow and torch tanks carrier for the local junkyard guy. I drove it away for $500.
  #34
Old 08-05-2011, 07:05 PM
sawmillman sawmillman is offline
sawmillman is starting off with a positive reputation.
A little info on the split wheels. These were used to mount 6 or 8 ply tires. Back then tire mounting machines were not as good as the ones of today. With the air out of the tire, you could remove the split rim and slide the stiff tire off the wheel. I had done many a split rim duelly wheels and it has been many years ago but I can remember doing some like that as well. Back then they were known as widow makers. If the rim was not installed right, it would fly off as the pressure came up on the tire and take your arm off.
I am just getting started good on my 52 F1 and it has 15" wheels. By the time I am finished I want to come up with the 16" as I am going to stay stock all the way.
  #35
Old 08-05-2011, 09:59 PM
I know some of the early 16" wheels were split. But I don't think later version of Ford's 16" wheel found on the light duty trucks like the Bronco used split rims. I know 66 Bronco's 16" wheel option used only 4 ply bias mud/snow tire. Maybe that's why the rim wasn't split???
  #36
Old 08-15-2011, 08:55 PM
still looking for 16"
Hey havi, did you ever get the pictures of your Bronco drive train with the 16" wheels on it? Thanks please let me know because I'm stilling for some 16" for my 66 Bronco.
  #37
Old 08-16-2011, 05:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by truckdog62563 View Post
Ilya - looks like a 16" x 4" was used on half tons between 1940 and 1946. Ford #01A-1015. There was also a 16" x 4" used by Merc for 40/41 model years, part #11A-1015. And by Zephyr for '39/'40. Part #06H-1015. These are all 5 lug x 5 1/2 circle.
Josh - There's been a gazillion different 15s available from 1939 on for the various makes and models. For purposes of our group, looks like '55 was the year a 15" x 5" was sourced on a F-100. Part #B5C 1015-A. Stu
Since 01A is a 1940 Ford Passenger Car prefix, the same wheel was used on cars (the '41 'Commercial' prefix is 01C). 11A = 1941 Ford Passenger Car, so both Ford and Merc's used the wheel.
If a specific '41 Mercury wheel (AFAIK, there wasn't one), the prefix would be 19M. Every 1946/48 Merc I've seen had 15" wheels, while the Ford's had 16's.
AFAIK, 1955 was the first year Ford offered 15" wheels on F100's...and...as standard equipment. 16's became as option (were available thru 1979).
  #38
Old 08-16-2011, 05:41 AM
Quote:
Originally Posted by 66 bronco roadster View Post
Hey thanks for the reply but I'm not sure if that's the same style of rims that would have come on a 66 Bronco.
I think you have an earlier version 16" wheel then a 66 model truck. I could be wrong seem to be a few different rims Ford offered. I would like if someone posted pictures of the different types.
Welcome to the wonderful world (not!) of Ford updated part numbers.
1966/71 Bronco ~ as original: B4TZ-1007-C .. 16" x 5" Wheel-non Split Rim / Marked #75192 / Use with external ("outie") hubcap.
Other applications: 1954/71 F100.
In 1972, Ford replaced B4TZ-1007-C with D2TZ-1007-E = Applications: 1954/79 F100, 1966/79 Bronco / 1975/79 F150.
What year was your Bronco? I'd guess 1966, but it could be 67-68 because it doesn't have side marker lamps and/or reflectors.
Side marker lamps were mandated by the NHTSA for all vehicles beginning model year 1968 (began September 1967).
1968/69 Bronco's had reflectors, 1970/77's had lamps that lit up.
  #39
Old 08-16-2011, 07:31 AM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Good to see you hanging around again,Bill.Hope you had a good vacation
  #40
Old 08-16-2011, 09:53 AM
Thanks for the bronco 16" wheel part number! I just have to find 4 of them. lol Any ideas where I might have some luck?
The reflectors for the Broncos really did start until the 69 model and like you said the side marker lights started in 70. Why the Bronco took longer then other Ford vehicles to get the new updates who knows??? I personally don't like the look of the side markers or the 69 reflectors it's one of the reasons why I like the 66-68 Broncos a little better.
Thanks Jeff
  #41
Old 08-17-2011, 12:38 AM
Side marker lights were mandated by the US Gov't for all 1968 foreign/domestic vehicles sold new in the US.
If not introduced for Bronco's until 1969, why are the part numbers 1968 related?
C8TZ-13380-A Right Body Side / C8TZ-13380-B Left Body Side / C8TZ-13380-C Right Front Fender / C8TZ-13380-D Left Front Fender.
You're looking at these Bronco's 40 some years after the fact. It's almost impossible to find an 'un-cut' 1966/77 Bronco, and...
Bronco's have prolly had more parts swapped around than any other FoMoCo vehicles except Model A's, T's, '32/34 Fords and 1965/68 Mustangs.
  #42
Old 08-17-2011, 12:03 PM
I don't know that much about the US mandate in 68 but I know for sure the side marker lights did not start until 1970! I understand mix and match Broncos thing (I have built a couple that way) and even cut Broncos still don't cut away the side marker area. Apparently most of the 68's did have the reflectors but I guess the very early production 68 didn't get them.
I don't have an answer for the C8TZ side marker light part number but they didn't show up until 1970 model. Who knows why??? Yes I think the early Bronco is one of Ford's biggest mutt, not only from used pieces and swaps but also right from the factory. It used stuff form the Mustang, Falcon, Econoline, and the F100 so tracking and finding so of NOS parts can be a bit tough a times.
  #43
Old 08-17-2011, 06:31 PM
C8TZ's are reflectors, were used on 1968/69 Bronco's. DOUZ-15A201-A (amber R/L front) & DOUZ-15A201-B (red R/L rear) light up.
These were used on 1970/72 Bronco's (1973/77 are different), 1970/74 Econolines and on the rear only of 1970/72 F100/350 Stylesides & Flaresides.
And if you need part numbers to learn what is what and which is which, the 1965/72 and 1973/79 Ford Passenger Car Parts Catalogs are availabe on CD's from hipoparts.com.
Bronco parts are listed in these catalogs 1966/79, not in the truck catalogs.
16.5 inch wheels. jleews6 1967 - 1972 F-100 & Larger F-Series Trucks 5 03-31-2014 08:38 AM
17 inch wheels on 2003? truckfella 1999 to 2016 Super Duty 3 11-24-2013 10:14 AM
Will 16 inch wheels fit a 77 f250? 77429highboy 1973 - 1979 F-100 & Larger F-Series Trucks 3 06-03-2011 02:48 PM
1955 F350 dually replacement wheels L.TONY F350 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-26-2006 02:05 PM
16.5 to 16 inch wheels Mike W 1967 - 1972 F-100 & Larger F-Series Trucks 10 01-22-2003 07:36 PM
Tags
16, 16x4, 1966, 45, 55, antique, f350, ford, inch, oem, size, steel, tire, truck, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
