Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Fuel System Guides
- Fuel Pump Reviews
Reviews and comparisons of top products
Airtex Fuel Pump issues
Well after 298k miles my 97 Aerostar fuel pump gave out. It started about 4k before quitting with symptoms of long crank times stumble from take off etc. It quit finally at home. Checked around and got an Airtex pump complete with sender at Autozone and installed it. 1000 miles later the new pump quit (with a full tank of gas). Reading thru forums Airtex pumps seem to have some issues. Anyone with similar stories? I have ordered a Motorcraft replacement from Amazon, and will return the other. I noticed on the Airtex that the fuel pickup is shorter meaning the gauge will read empty with more fuel left in the tank .
I think I now know the tell-tale sign of a pump going bad; the most obvious one is if it starts making more noise, or groans instead of whines. The final signs are the hard starting, stumbling, and sometimes engine knock. Unfortunately, this is not a failure that you can easily prepare for, so it's best to look for the early signs.
I've had four Aerostars totaling about one million miles and none of them have failed on me......so far.
Actually, replacing the fuel pump on the Aerostar is not that bad, if you're tank is less than half full. I jacked up the side of the van to get under it, and just lowered one side of the tank enough to get at the mounting plate on top. I was investigating a leak in that area (found to be caused by an improperly installed gasket), but I could have easily replaced the pump at that time. Something that helps the pump live longer is to not let the tank get too low. The pump needs to circulate the gasoline to keep itself cool, and running low enough to have it suck fumes will overheat it very quickly.
When I said "whine", I meant a steady, usually inaudible unless you're right next to the tank, high pitched whine. The one on my Mustang had started to groan unevenly, and should have taken the clue.
PapaBearYuma
05-02-2017 10:05 AM
Murf7.3
15
09-13-2016 06:55 PM
Big-Dawg
09-01-2015 06:36 PM
fjazzbass
09-01-2015 12:44 PM
