Frozen (literally) #7 Cylinder, Ford will not warranty
#31
My truck has gold colored antifreeze and my other diesels use the reddish purple antifreeze because of this problem.
#32
Umm...truck was towed to Ford because it wouldn't start. Several weeks later they called and said that these pictures were what they found.
#33
No, they will just foam more and also the gold has rust inhibitors that extend the life. I guess it would be equivalent to adding Water Wetter or other additives to your coolant that serve the same purpose.
#34
Sorry if I missed this, but what was Ford's reason foir denying the warranty claim? We have to PROVE it was their fault to get warranty work done? If I have documnentation on proper maintenance, isn't the burden of proof on the dealer/manufacturer for denying warranty (even to the point the would have to have some proof of "abuse or misuse?)?
#35
#39
So the dealership has said that engineering told them to go ahead and replace the motor. No official approval on the warranty yet, but it's a really good sign.
Here's a link to the other posting:
Frozen (literally) cylinder #7. Ford says warranty now void! - Page 28 - Ford Truck Enthusiasts Forums
#43
#44
Where did you get your fuel from?? I know that a lot of fuel used in the industry i work in (oil/gas) especially from UFA has a lot of water in it (i know it sounds outrageous). A lot of dyed fuel used on the rigs is horrible fuel, i have taken samples and put them in our centrifuge and you can see the separation of water and fuel. It was very small but it was there.
#45
OK, obviously that is water in the piston, not antifreeze of any kind.
Even antifreeze with a low freeze rating like -10 will only slush up at -35, not turn rock hard and split steel.
fordman75
Ford Truck Parts for Sale
26
07-30-2013 03:31 PM
Red_Stallion
1999 to 2016 Super Duty
516
03-17-2010 06:38 PM
ford truck oldboy460
20
01-14-2009 10:33 PM
BanksPSD
30
04-02-2008 08:36 AM
