How do I pass a wire from inside the cab into the truck bed using the pass through - 2012 crew cab
I want to pass a cigarette lighter extension cord from the under seat storage of my crew cab into the truck bed. How do I find, get access to, and open up the pass throughs that I understand are in the rear wall of the cabin and the front wall of the bed? I should mention the bed has the factory sprayed liner.
Thanks
There's way too much that I don't know about this truck, but I'm learning, thanks to you folks.
Thanks
Thanks
Thanks
And I have bed LED light installed using Walmart product. I bought 6 LED strips and it looks great.
Thank you, but, that circuit isn't always on, is it? I didn't mention why I need the access, but this is for a cooler, and I'd rather have it on unless I switch it off.
Run the wire from the cab to the door sill, remove the sill cover and there are grommets in the floor of the sill. From there you can run under the cab and into the bed where ever you want to go. There are several access points in the bed (stake pockets, and I think the front of the bed has a grommet too.) then youre all set. To have an always hot wire you may need to run a dedicated wire from the battery. If it were me, I would run an always hot to the cab, put it on a switch, then run from the switch as I described to the bed.
I would want to connect them to a up fitter switch inside the cab. But I don't think there is a grommet in the bed of the truck, just had a Line X installed today and it does not look like any grommets in there, but there maybe some type of access hole I could use.
I did remove the yellow off the back and added the chrome ones on, I like them both too.
My racing buddies are forever asking whether their SUV can haul some proposed trailer; I tell them to get a truck.
I guess I am not understanding why you even need to route this wire into the cab. Why not go from the battery, through a fuse, then along the frame rail to the bed?
Alternately, installing upfitter switches would allow you to switch the circuit, but the relays would still be under the hood.
If you want a switch controlling the circuit (and since this would be a fairly high amperage circuit) I would install a relay under the hood to switch the high amperage circuit, controlled with a switch in the cab, but utilize one of the blunt cut wires behind the master cylinder to pass the on/off signal through the firewall.
