F100 Steering Wheel - Ford Truck Enthusiasts Forums
F100 Steering Wheel
Old 01-04-2010, 06:54 PM
Voodoo ChildVood's Avatar
Voodoo ChildVood Voodoo ChildVood is offline
Voodoo ChildVood is starting off with a positive reputation.
F100 Steering Wheel
Can anyone please tell me what year steering wheels will fit a 1971 Ford F100. For example will the years 1973 thru 1979 work on this. Thanks!!!
Old 01-05-2010, 01:16 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Welcome to FTE
1971/77 F100/350's, and 1974/77 Bronco's are the same (except for 1975/77 F100/350's with Cruise Control).
1971/73's were originally available in Black, Blue, Red, Green, and Tan.
In 1974, Ford obsoleted all these wheels except Black which has been reproduced by Dennis Carpenter.
Old 01-05-2010, 02:46 PM
71 Steering Wheel
Thank you very much for the information!!!
Old 01-07-2010, 11:55 PM
red403's Avatar
red403 red403 is offline
red403 is starting off with a positive reputation.
They changed something can't remember what in 1979. Anything 78 and lower should work not saying it will for sure though.
Old 01-08-2010, 02:08 AM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
77 and under 78 is different
Old 01-10-2010, 03:37 PM
1978/79 is the same, but not the same as 1971/77.
Old 01-16-2010, 02:24 AM
red403's Avatar
I am installing a tilt column out of a 1979 truck in my 67. Will a steering wheel from a mercury capri or mec zepher work or does it have to be from a truck?
Old 01-16-2010, 12:03 PM
Fordgery's Avatar
Fordgery Fordgery is offline
Fordgery is starting off with a positive reputation.
Quote:
That swap sounds like a good plan!
Old 01-16-2010, 01:02 PM
bmuhlbach's Avatar
the car wheel will fit I put the 3 spoke from a Mustang 2 on my 78 .the 85 Capri I had the wheels are totally different
Ford F-100 Steering Column Replacement fish1940 1967 - 1972 F-100 & Larger F-Series Trucks 6 10-12-2016 07:43 AM
1968 f100 steering column dbyrd342 1967 - 1972 F-100 & Larger F-Series Trucks 7 05-24-2016 02:37 PM
Steering wheel help Damifiknow 1967 - 1972 F-100 & Larger F-Series Trucks 5 06-03-2015 01:43 PM
64 Steering Wheel - what other years work? svolpone 1961 - 1966 F-100 & Larger F-Series Trucks 4 05-22-2014 02:28 PM
Compatible Steering Wheels Binkowski 1967 - 1972 F-100 & Larger F-Series Trucks 9 03-23-2014 01:58 AM
Tags
16, 1962, 197177, 1972, 1974, f100, fit, ford, red, steering, truck, trucks, wheel, wheels, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
