Frozen (literally) cylinder #7. Ford says warranty now void!
#46
on
Completely stock crew cab base model...except cruise and air conditioning....oh and a block heater.
Yes it was snowing and have definitely seen issues with snow/ice buildup on the intake in the past....however....had the water pulled through the intake would it not affect all cylinders and not just be heavily isolated to #7?
#47
That would have to be some crazy angle on the truck/valve timing to find only ONE intake valve open with the rest on that bank completely closed. I know what you're saying but I just don't see it happening.
#48
and seriously.. does anyone find a logical explanation for this much water in the intake, where the truck has to be at a special angle, and the intake valve on THAT cylinder is open so it can (while melted) run down there and THEN freeze? the intake tube, filter, etc will freeze LONG before the block does.. the intake TUBE would have to be 1/2 full of snow.. the filter should be destroyed (with a hole) to allow that much snow past it. AND the driver would have to have run into some serious snow JUST before turning the engine off..
and I agree, the pics are worrisome..about the only way to get there with ice is to look inside the cylinders with a borescope thru the injector holes, and see the ice, and decide right then to pull the cab and head. where are the pics of the borescope output.. no one had a cell phone that day? come on.. this would have been a shock to anyone to find this situation..
Sam
Sam
#51
#52
At some point, I wonder if the (a) dealer did something that required a coolant change, maybe even before the truck was bought.
Get an OASIS on this thing. Fast.
#53
#54
That's why I said something is weird about all of this. If the truck was indeed never touched except "topped off", that green coolant is the WRONG STUFF for a 6.4
The 6.4ls had radiator cracking issues, especially in the earlier trucks. The dealer could have swapped the radiator and the coolant before the customer even took delivery. Don't know if an Oasis would show everything that was done even prior to taking delivery.
#55
Not sure about the coolant being swapped out completely, but this truck is post radiator recall and is a 2009 model year.
The air filter was checked and is in perfect condition. It still looks brand new.
Some Ford higher ups are going to be taking a look at it now so it the waiting game now.
Based on the responses here it would seem to be a fairly cut and dried case of head gasket failure?
#57
no other explanation makes sense.. (and per judge judy, "if it doesn't make sense, it's not true")..
and still don't get why they need to replace complete engine for a little water if it didn't crack the block. and I think 200+ degrees to -31 AND crack the block into the cylinder bore on ONE overnight is unlikely. so, you should be able to see the damage to the head gasket.
Sam
#58
seems that way to me.. did you happen to notice any white smoke in the exhaust lately, before this last drive? I really can't believe that this is THE first failure (and it froze solid), but weirder things have happened..
Sam
Sam
No driveability issues or smoke whatsoever. Truck was driven up the province and parked. No reason to believe there was an issue and it had just been in for servicing a week ago.
At those extreme temperatures materials can do funny things and gaskets can harden or contract, metal can become brittle, so it is easy to say that there could have been some crack or weakness that is no longer evident.
#59
#60
right.. if it wouldn't turn over, then not much damage can be added to the freeze damage.. if its not a block, it can't be much..if water only in ONE cylinder, then when it froze and expanded, it would push the crank back a tiny bit (in either direction), but that shouldn't cause damaged.
I dropped a valve in my 460 and the starter couldn't turn the engine due to debris but nothing else was damaged from my trying to turn it over.
So like u, I am confused..
Sam
Sam
