Do I have an FMX block?
Well I started looking at all the places where the block would have numbers.
Numbers on Block are D1AE-6015-A2C
It appears to have four numbers behind the intake mani where the oil pressure sender is but the first number is distorted it might be a 3,8,X? then J21.
Head on driver side D3AE-G2B
I was checking where the motor mounts bolt up on the block and its dead nuts the same as this know FMX http://image.wetpaint.com/image/1/jg...5103/GW645H483
The tranny that came with the engine had a removable bell housing and had a big pattern. Its currently bolted to a big pattern C6.
Read the posts here. Doesn't look like it.
https://www.ford-trucks.com/forums/8...agon-400s.html
You are trying to determine if you have a 400 block with the SBF bell pattern, right? That's a D3... casting number if I'm understanding the posts correctly. Head & manifold casting numbers mean nothing, it's the block casting.
The FMX also could have had the 335/385 pattern bell afaik, so just because there was/is an FMX doesn't make the block anything rare.
airharley
07-16-2020 05:38 AM
El Guapo 48
07-19-2016 02:04 PM
hbpaints
08-07-2010 11:38 AM
