Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Fog Light Modifications
Overview of popular modifications to customize your truck
Fog/High Beam Mod Instructions - Anti-BrightBox Mod
#47
This is for all those trucks with the weird wiring.So if you don't have that green wire with black tracer on the fuse block or the white wire with black tracer at the headlight switch.Five min.job All you have to do is pop out the headlight switch. Take the yellow wire and the dark brown wire an scotch lock them together your done.
#48
Time to bring this thread back to life !!! I've read a few threads and none seam to relate to my particular set up. I have a 2000 f350 xlt with no factory headlights. I upgraded to a gos headlight harness for brighter lights and it worked great. Since I still had the other vacant headlight connector, I decided to add factory fog light with the purchase of an additional harness and it works great. Now, problem I'm running into is no fog light when high beam lever pushed forward (lever pushed away and stays)so both high and low stay on. Fogs do work with when flashing (lever pulled backwards or to steering wheel or you). Whats the wiring difference in the two directions wiring wise? Thanks
#49
#50
#51
#52
#53
Still remain willing to eat crow on this one, but am simply coming up short where running the high's and fogs goes against any laws / rules / regulations with the headlamp assembly that our SuperDuty trucks use. Naturally, doing so where it will blind oncoming traffic is illegal in many (if not all) places, but we can do that without the fogs and an OE configuration.
Now, change the scenario a bit to a headlight assembly that uses *separate* high and low beam lenses, and Yes, running fogs at the same time as the high's will likely not comply as that creates 6 forward facing lights at the same time.
#54
I would think that it wouldn't pertain to our trucks since our high and low are in the same housing and on the same bulb. Unless an officer was to physically check to see if you have your highs and lows wired together( highly unlikely), you technically are only running four lights. I think the law states 6 lights, as in 6 individual lights.
reptar0077
1999 to 2016 Super Duty
12-04-2017 06:00 PM
Firekite
6.7L Power Stroke Diesel
07-22-2016 11:27 AM
Vince79vette
01-06-2014 08:50 PM
