Strange 460ci misfire problem
Old 05-13-2010, 10:18 PM
RebusCom's Avatar
RebusCom
RebusCom is offline
I have a 1989 E350 with 460ci engine & C6 trans. It runs fine unless the parking lights or headlights are turned on. With lights on two cylinders drop out. If I give it lots of gas one of them will kick back in leaving one cylinder misfiring but back to cruise and two cylinders die. With lights off all cylinders run all the time. BTW, this van has quite a few marker lights so the light draw is somewhat higher than most vans.
I checked voltage at the "downstream" side of the main accessory breaker (mounted on chassis near battery) to ground with engine running it holds a constant 13.8v with lights on or off. With the engine off it measures 12.8v with lights off and 12.4v with lights on.
Old 05-13-2010, 11:19 PM
tinaheels's Avatar
tinaheels
tinaheels is offline
c9 tranny ? really i think u mean a c-6 trans
Old 05-24-2010, 03:13 PM
wizzy214's Avatar
wizzy214
wizzy214 is offline
post this in the 67-newer econolines
Old 05-24-2010, 07:06 PM
RebusCom's Avatar
RebusCom
RebusCom is offline
I did over a week ago.
https://www.ford-trucks.com/forums/9...lights-on.html
So far nobody has any suggestions.
Old 05-24-2010, 07:52 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
check all grounds and clean them. especially the ones from the frame to the body that just clip on. you are robbing the grounds from the ign with your lights
saltydog463
07-22-2016 04:10 PM
robert951
02-24-2015 10:31 PM
jakeupowens
3.8 & 4.2L V6
04-16-2014 08:13 PM
dbartle
1997 - 2003 F150
10-25-2012 05:28 PM
RebusCom
05-17-2010 08:36 AM
Quick Reply: Strange 460ci misfire problem
