Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-03-2010, 03:00 AM
threefiftyone's Avatar
threefiftyone threefiftyone is offline
1996 Ford F-350
threefiftyone is starting off with a positive reputation.
Slow Windows...
Well, I think the (Driver's side for now) window is finally going out. Today, it has been making a terrible squealing sound as it nears the top of the door.
I ran the window back up, then pushed the button down to try to pinpoint the sound, and the window would not roll back down. No response at all from the window button. All other windows work fine, although terribly slow.
I'm gonna yank the driver's side door panel off and i'll let you know what I find.
__________________
Don't ya just hate those a_$_$_h_o_l_e_s who post just to increase their numbers but actually have nothing meaningful or relevant to say? I DO. So unless you're going to make a difference, just don't even bother. Everyone else will see that too. Have a good day
  #2 (permalink)
Old 01-03-2010, 05:49 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
the switches themselves also like to get corroded on the contacts
I had that issue with my 06 F-150.
feel your pain though about the slow window action. my right rear window is acting up, but I'm scared to let the idiots at any of the 3 Dealerships touch it.
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 01-04-2010, 10:37 AM
gddyup's Avatar
gddyup gddyup is offline
Garage is empty, add now
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
Same problem here. My D/S window is very slow and it doesn't help that it's been snowing and freezing temps around here the last 2 weeks. I've been succesful with other cars putting some silicone down the window tracks with the window down. If that doesn't work, warranty time.
  #4 (permalink)
Old 01-04-2010, 02:44 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
My guess is the cable snapped/came off the pulley or the pulley broke. Look near the top, inside the door for two small pulleys that wrap up the cable and bring the window up and down. Might need a mirror and some good lights.
There is a TSB for slow windows regarding the rubber track it slides into. I had my rear passenger window regulator and motor replaced twice. First time for painfully slow movement-20 seconds to roll up. Second time for a loud creaking noise from the newly replaced regulator. I suggest you pull the panel and load up the track with more lithium grease where the white sliders move on. The parts on the regulator are extremely cheap feeling.
TSB 08-19-4
09/29/08
REAR POWER WINDOWS OPERATE SLOW / BIND /
STICK - BUILT ON OR BEFORE 10/8/2007
FORD:
2008 Expedition
LINCOLN:
2008 Navigator
This article supersedes TSB 08-13-4 to update the Service Labor Times.
ISSUE
Some 2008 Expedition and Navigator vehicles built on or before 10/8/2007 may exhibit rear power windows that operate slow or stick I bind when operating.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Verify the power window sticks I binds or is slow by visual inspection.
2. Replace the rear door glass top run for the affected window. It will be necessary to remove the door glass prior to glass run removal per Work Shop Manual (WSM), Section 501-11.
3. Inspect the outer glass weatherstrip while door panel is off for correct positioning. Incorrect positioning could cause a binding concern due to excessive pressure on window.
a. Correct positioning of the outer glass weatherstrip would have the inside lip sitting flush against the inner door sheet metal.
b. No gaps would be felt between the outer glass weatherstrip and inner door sheet metal.
c. Make sure the four (4) retaining tabs are aligned and inserted correctly in the retaining holes.
d. Replace the outer glass weatherstrip if retaining tabs do not seat or the outer glass weatherstrip does not stay in position, refer to WSM, Section 501-11 Glass, Frames and Mechanisms.
4. Recheck power window operation.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
081904A 2008 Expedition, Navigator 0.7 Hr.
Built On Or Before
10/8/2007: Replace The
Rear Door Top Glass Run
And, Outer Glass
Weatherstrip If Necessary
Includes Time To Remove
And Install Door Glass And
Inspections: One Rear
Door (Do Not Use With
27406B, 27406B14,
27406B12, 21456A)
081904B 2008 Expedition, Navigator 1.3 Hrs.
Built On Or Before
And, Outer Glass
Inspections: Both Rear
Doors (Do Not Use With
27406B, 27406B14
27406B12, 21456A)
DEALER CODING
CONDITION
BASIC PART NO. CODE
7825766 07
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #5 (permalink)
Old 01-05-2010, 01:18 PM
hjsimpson's Avatar
hjsimpson hjsimpson is offline
2007 Ford Expedition
hjsimpson is starting off with a positive reputation.
Same thing happened to me.. the driver side window started to bind and squeak and in freezing temps it would not operate.. Eventually mine stopped working completely... The passenger side did the same thing but has never stopped working.. Brought it to the dealer.. on the driver side they replaced the regulator on and the passenger used lubricant.
Drive side window now works even in freezing temps.. but my passenger side still squeaks.
I'm projecting at somepoint the regulator will go on the passenger side and then I will have to pay out of pocket.. when it should have been resolved the first time around.
I would take it in if its under warranty.
__________________
2007 Ford Expedition XLT 4X4
Husky Liners Molded Mud Guards ~ Ford OEM Side Window Deflectors ~ WeatherTech Floor Liners & Cargo Liner
Tinted front windows ~ Hunter Bull Bar ~ HIDX 4" HID lights ~ 4" Magnaflow SS rolled angle exhaust tip
Quote:
Never, never, never give up. -Winston Churchill
  #6 (permalink)
Old 01-13-2010, 01:29 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.1ATony has a great reputation on FTE.
You can try to put some silicone spray on the weatherstrip to see if that frees it up at all
__________________
GREAT SELECTION OF TOW MIRRORS
Tony
1A Auto Parts
CALL ME DIRECT1-866-403-3393
Shop For: Ford Truck Parts
Tags
06, 2004, 2005, door, drivers, expedition, ford, front, power, regulator, slow, truck, tsb, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
