How to tell if the master cylinder is bad? - Ford Truck Enthusiasts Forums
Old 01-02-2010, 11:39 PM
cabloom300's Avatar
cabloom300 cabloom300 is offline
cabloom300 is starting off with a positive reputation.
I replaced about half the brake lines in my 76 highboy and after bleeding them i still only get a little brake pressure and its close to the floor. How can i tell if its the master cylinder or how do i find the problem? Thanks
Old 01-02-2010, 11:49 PM
1974F-100's Avatar
1974F-100 1974F-100 is offline
1974F-100 is starting off with a positive reputation.
I am not sure exactly how to tell but they are usually cheap enough to change if in doubt ($15.99 at AZ w/ core).
I changed all my lines and found that the best way for me to get all the air out was by gravity. I went to the back right and the worked my way up leaving the valve open enough to drip and kept adding fluid, it also flushed most of the old out and made me feel better...
Best of luck!
Old 01-02-2010, 11:53 PM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
When it does stop close to the floor does it stay there or will it bleed down.
Old 01-02-2010, 11:56 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
If you can eliminate the rest of your brake lines, hoses, wheel cylinders and calipers as the culprit then it's a pretty safe bet your MC is bad.
Old 01-03-2010, 01:14 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
I don't recommend replacing any part simply because it's cheap to do so. Only replace something until you know it's bad. Are you able to pump the pedal several times to build pressure, or does the pedal go to the floor every time?
Old 01-03-2010, 03:35 AM
1974F-100's Avatar
Quote:
Must be instilled in me from the Navy, PMS. Preventive Maintenance Systems. I change just about anything that has got some age on it.
Old 01-03-2010, 04:20 AM
Riderman Riderman is offline
Riderman is starting off with a positive reputation.
Quote:
Help us help you sir. Did you replace the Front brake lines or the rear? If the front, did you bleed them at both calipers? If rear, did you bleed them at both wheel cylinders? How did you bleed them? GRAVITY bleeding is NOT an option! It may get you close, but what about that air bubble in the brake line above the rearend housing? That exact issue caused a crash and got a co-worker fired recently...His.. defence.."I gravity bled them"
Have someone pump the brake pedal with the engine running at least 3-5 times, and have them HOLD it. When you open the bleeder, have the person pushing the pedal keep it pushed to the floor untill you tighten the bleeder, then they can let their foot up. Start at the left front, crack the bleeder untill clear fluidand no air is comming out. Repeat the pedal pumping action and Fill the master ceyclinder before it get's below 1/3 rd of the way empty. Repeat this proceedure to the right front, left rear, and finaly, right rear. If no fluid comes out of any bleeder, Email back to us..we can help find the issue
Old 01-03-2010, 06:14 AM
Quote:
All good advice but you want to start at right rear and work your way to left front.
Old 01-03-2010, 06:27 AM
Quote:
All jokes aside..WHY? I've read all the wives tales about bleeding brakes and tried them all... well, I'll let you explain the rear way first..not that there is a farts difference IMHO..the end result is the same. I'm probably wrong though. But since it was worth a responce from you... Older Volvo station wagons even requested bleeding the right front first, why?
Power Bleeding is the best way...even with anti-lock brakes.....front\rear, right left, I've done it several way's, the end result should be clean fluid with no air. Bleed once a year and see how long a few dollars worth of fluid keeps your lines\and cylinders\calipers working like new for many years.
Old 01-03-2010, 10:40 AM
GQROD GQROD is offline
GQROD is starting off with a positive reputation.
If you press the brake pedal and it feels spongy like it's pressing back against your foot that's one way to determine your mc is bad.
There may be others like if it has an obvious leak.
Old 01-03-2010, 10:51 AM
wdfp wdfp is offline
wdfp is starting off with a positive reputation.
You might try leaving the cover off, stand in the doorway where you can see the master cylinder and slowly depress the brake pedal, you should see the brake fluid swirl as you push the pedal down, too fast and it will squirt right out, if not, it probably bad....
Also if there is air in it you should see little bubbles rising in the first inch or so of pedal travel... This has worked for me in the past.. After doing most of the above described procedures to make sure the are bled as well as possible.
Old 01-03-2010, 12:55 PM
If you can pump it up and it stays as long as you hold it and does not slowly bleed to the floor it is good.
Changing a good master cylinder with a cheap rebuilt one just takes up your time and money nothing else.
On these rigs a lot of the time you will never get your pedal back where it needs to be until you adjsut your rear brakes. And I know it was there before but if the wheel cylinders are to far out you have to adjust them to get it back.
Old 01-03-2010, 03:06 PM
cabloom300's Avatar
First off i replace from the valve back with new lines. My bleeder screws and rusted BAD and couldnt seem to get them out. So just thinking off the top of my head i unscrewed the end of the new line and bled it like that. How effective is this? It could be i still have some air in them but the back seemed good. Do i need to bleed the front as well even if i just did the back ones? Need some help as im not to familiar with brakes. Thanks all
Old 01-03-2010, 03:42 PM
Here comes paul harvey with the rest of the story. lol you need to get your bleeders operrational or replace your wheel cylinders.
Old 01-03-2010, 05:16 PM
4x4 Bart 4x4 Bart is offline
4x4 Bart is gaining momentum as a positive member of FTE.
I agree.......X2
1977 Power Brake Challenge Hawkmcgee 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-26-2014 09:07 PM
Leaking Brake Fluid in cold weather. gdellinger1 Explorer, Sport Trac, Mountaineer & Aviator 4 01-25-2014 09:36 PM
Master cylinder - how to get pushroad seated DougieWebb 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-15-2013 11:41 PM
brake booster or master cylinder JCastellaw 1966 - 1977 Early Broncos 3 10-04-2011 08:20 AM
adjusting brakes Schuyles 1961 - 1966 F-100 & Larger F-Series Trucks 7 04-04-2010 09:06 AM
Tags
1999, bad, bleeding, brake, brakes, cylinder, f250, floor, fluid, ford, master, no, out, pedal, pushes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
