How to tell if the master cylinder is bad?
I am not sure exactly how to tell but they are usually cheap enough to change if in doubt ($15.99 at AZ w/ core).
I changed all my lines and found that the best way for me to get all the air out was by gravity. I went to the back right and the worked my way up leaving the valve open enough to drip and kept adding fluid, it also flushed most of the old out and made me feel better...
Best of luck!
Best of luck!
Must be instilled in me from the Navy, PMS. Preventive Maintenance Systems. I change just about anything that has got some age on it.
Have someone pump the brake pedal with the engine running at least 3-5 times, and have them HOLD it. When you open the bleeder, have the person pushing the pedal keep it pushed to the floor untill you tighten the bleeder, then they can let their foot up. Start at the left front, crack the bleeder untill clear fluidand no air is comming out. Repeat the pedal pumping action and Fill the master ceyclinder before it get's below 1/3 rd of the way empty. Repeat this proceedure to the right front, left rear, and finaly, right rear. If no fluid comes out of any bleeder, Email back to us..we can help find the issue
Power Bleeding is the best way...even with anti-lock brakes.....front\rear, right left, I've done it several way's, the end result should be clean fluid with no air. Bleed once a year and see how long a few dollars worth of fluid keeps your lines\and cylinders\calipers working like new for many years.
You might try leaving the cover off, stand in the doorway where you can see the master cylinder and slowly depress the brake pedal, you should see the brake fluid swirl as you push the pedal down, too fast and it will squirt right out, if not, it probably bad....
Also if there is air in it you should see little bubbles rising in the first inch or so of pedal travel... This has worked for me in the past.. After doing most of the above described procedures to make sure the are bled as well as possible.
If you can pump it up and it stays as long as you hold it and does not slowly bleed to the floor it is good.
Changing a good master cylinder with a cheap rebuilt one just takes up your time and money nothing else.
On these rigs a lot of the time you will never get your pedal back where it needs to be until you adjsut your rear brakes. And I know it was there before but if the wheel cylinders are to far out you have to adjust them to get it back.
First off i replace from the valve back with new lines. My bleeder screws and rusted BAD and couldnt seem to get them out. So just thinking off the top of my head i unscrewed the end of the new line and bled it like that. How effective is this? It could be i still have some air in them but the back seemed good. Do i need to bleed the front as well even if i just did the back ones? Need some help as im not to familiar with brakes. Thanks all
