Auxillary Transmission between BellHousing,and Trans. - Ford Truck Enthusiasts Forums
Old 01-02-2010, 11:19 PM
supercab4x4dually's Avatar
supercab4x4dually supercab4x4dually is offline
supercab4x4dually is starting off with a positive reputation.
Question Auxillary Transmission between BellHousing,and Trans.
Has anyone here heard or has installed a auxillary transmission to there NP435 or T18/19?I have a 460/NP435/NP205 in my 1979 F-350 Supercab dually 4x4,and ive found myself doing alot of highway driving,and man I NEED a fith gear bad!!!I was on Jeff's Bronco Graveyard and ran across the Ranger Torque Splitter For 1971-87 4-Speeds ,and liked the price due to the fixed incom im on.Well I went to a local truck shoe/swap meet,and found a unit called double trouble,and it's the same thing as what JBG has but instead of manually shifting it my unit has a Eaton electric shift motor on it so it's shifted with a switch.It say's it will give me up to 28% overdrive.Has anyone here messed with these at all or know anything about them?
Old 01-02-2010, 11:56 PM
justiz00 justiz00 is offline
justiz00 is starting off with a positive reputation.
Knew a guy back in college that had a ranger gear splitter between his bell housing and his transmission. He had an electric motor on it to shift it and was controlled by a push/pull switch on his shifter (madmax style). Had it behind a 6.5 chevy diesel in an old Kaiser.
Next to my old stang.
Old 01-04-2010, 12:58 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Probably the same info you have already. Note their comments about noise and cost difference compared to a NV4500 conversion. Note you have to move everything back 7 1/2", which will mean two new DS.
Ranger Overdrive
Old 01-04-2010, 03:03 PM
I had brandnew diveshaft's made when I built truck,and the guy who built them is willing to shorten the one,and make front shaft longer for a super low cast becuase he made the shaft's.Mine isn't a Ranger Overdrive,mine is a Double Trouble 2XT.The only differance is mine is electricly shifted,and the Ranger is a shifter lever.
Old 01-15-2010, 06:17 PM
Here is the 2XT Double Trouble overdrive Unit
Old 01-16-2010, 01:24 AM
Do you have a link or company name of who makes and sells that?
Searching "double trouble..." leads to all kinds of non-transmission stuff...
Thanks
Old 01-16-2010, 05:50 AM
magusjinx's Avatar
magusjinx magusjinx is offline
magusjinx is starting off with a positive reputation.
Looks like it is made by "PAT PENDING" ...
Old 01-16-2010, 11:30 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Did a little research. The unit is a Double TORQUE 2xt. Seens likely it was made by Power Torque Industries Inc. of Texas. Can`t find anything on that company though.
Old 01-16-2010, 03:46 PM
That's who made it,Power Torque Industreis inc. In Texas.They are nolonger at there adress that's on install instruction's.I found a ad in Popular Mechanics magizine jan.1984 issue.But all that's all it say's.All the newer unit's like the Ranger Overdrive are made in a cast aluminum case,and my Double Trouble is cast iron cased.All the newer unit's are manual shifted,and mine is shifted with a electric motor.Just like a 2 speed rear end.Im in the process of installing now,and will post pic.'s as I go.
Old 01-17-2010, 07:53 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
The double torque 2xt has not been manufactured since sometime in 84. Power Torque Industries applied for a patient in 82 and then took no further action. The name is up for grabs at this time.
Only name close is Power Torque Inc but they don't make automotive aux trannies.
Old 01-17-2010, 08:11 AM
Supercab, pics would be interesting. Good luck with the install.
Old 01-19-2010, 01:58 PM
Started AUX Tranny install,here's some start pic.'s
[IMG][/IMG]
Old 01-19-2010, 03:36 PM
Good man. Keep `em coming.
Old 01-19-2010, 04:21 PM
I had to cut that bearing retainer to make it so it would fit into the back of the 2XT double trouble.It say's so for correct fit.I have it installed back into truck.I just ran out of battery for the camera.The shift motor for unit fit's under floor perfect with no modifacation's to floor needed.More pic.'s to come.Like my idea of the perfect transmision jack?Work's great,and make it's easy to line back up going back in truck with transmision,plus no jack to have to work around under the truck.
Last edited by supercab4x4dually; 01-19-2010 at 04:28 PM. Reason: forgot something
Old 01-20-2010, 01:11 PM
I did notice the crane. Wondered what navy yard it came from!
Help needed with NP435 issue RJK671 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-08-2013 06:32 PM
NP435 to NP205 adapter JKessler00 WTB - Parts & other 3 11-25-2011 07:59 AM
np435 shift fork pads keith66 1961 - 1966 F-100 & Larger F-Series Trucks 1 09-08-2011 11:36 PM
Tremec RTS 4spd. w/ OD little_mule 1978 - 1996 Big Bronco 13 04-01-2011 11:38 AM
WARN Industries Auxlliary Transmission for divorced NP435 and NP205 4x4x429 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-03-2009 12:31 AM
Tags
1971, 2xt, auxillary, bellhousing, double, f250, ford, gear, overdrive, prices, spliter, torque, transmission, truck, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
