Will '72 nose fit on '76
Old 02-21-2010, 07:25 PM
71torhino`'s Avatar
71torhino`
71torhino` is offline
Looking at a '76 Ranchero and have access to a '72 Torino GT nose. I have always liked the '72 better. Can I bolt the '72 onto the '76?
Old 02-21-2010, 08:37 PM
66gpw's Avatar
66gpw
66gpw is offline
I think you could bolt them on. for sheetmetal wise. The body lines at the doors and fenders are the same.
The problem could be the bumpers. The 72 has a narrower bumper and it is molded to the contour of the header and grill, where the 76 is a much straighter bumper. The 2nd problem with the bumpers is the mounting. The 72 has mounting brackets and arms. Where the 76 has rebar bumpers with those collapsible bumper shocks that mount to the frame.
To me the only issue would be the bumper areas. Are they able to bolt right on from a 72 frame to a 76.
Old 02-24-2010, 09:34 PM
grclark351's Avatar
grclark351
grclark351 is offline
yes, the frame horns are different, they can be cut off, swapped and welded. there's also a cowl to fender mount bolt that's different, it can be worked either of 2 ways; add the mount point to the cowl or swap the inner fender brace from the later fenders to the 72 fenders. while it does seem like a lot of work the swap is very popular.
Old 02-24-2010, 10:25 PM
66gpw's Avatar
66gpw
66gpw is offline
Glad to see those pics on the other thread you posted grclark. I forgot uys use to put Edsel front clips on the 58 and 57 Rancheros.
Seening the 72 Montego Gt clip fitted on a 79 Ranchero with the thinner bumper should help with a visual.
Old 02-26-2010, 12:58 AM
71torhino`'s Avatar
71torhino`
Thanks for the help. Unfortunately the '76 got away from me so I am back to work on my '48 COE that is going on and '84 F-250 frame.
