Custom '08 Fender Vents From Billet Badges.com - Ford Truck Enthusiasts Forums
Old 01-02-2010, 03:53 PM
pbeering's Avatar
pbeering pbeering is offline
pbeering is gaining momentum as a positive member of FTE.pbeering is gaining momentum as a positive member of FTE.
About two wildfires, and some months ago I contacted Steve Smart from Billetbadges.com about creating some custom vents for the '08. He figured out the tooling and after some exchanges of artwork and concepts:
Step 1 Remove existing vents, which are chromed plastic and held in with clips.
Old 01-02-2010, 03:55 PM
pbeering's Avatar
Once the old vent was removed, the wiring could be completed. Note that heat shrink connectors were used since this will be in the salt.
Old 01-02-2010, 03:57 PM
pbeering's Avatar
After the paint underneath was cleaned with a mix of alcohol and water, dried and warmed with a heat gun, the new machined vents were installed.
Old 01-02-2010, 04:00 PM
pbeering's Avatar
These incorporate the Whelen LINZ6, a 6 LED linear head with very good off axis warning. They are very bright.
For those in the fire service or other emergency vehicle applications, Steve Can customize these to reflect your department, unit number, etc.
Old 05-30-2013, 05:08 PM
robert_l_ross's Avatar
robert_l_ross robert_l_ross is offline
robert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputation
First off brother - those are SICK!!
I've contacted Billet and asked for a similar set, but with the first line reading the factory "EXCURSION" font then the middle line of "6.8L V10".
Can you tell me where you found the lights that fit inside that badge - and did you have to drill new holes in the fender to get the wiring through, or did the wiring fit through an existing hole under the original badge?
Thanks!!!
Old 05-30-2013, 05:16 PM
pbeering's Avatar
These fit the 6.4 diesels (2008-11) which have functional vents. (No cutting) the Billet product would fit your Excursion, but you will have to cut a hole for the light and wire.
The light is a Whelen LINZ6 which is switched seperately to allow side only warning. The light head is attached to the billet vent with sensor safe RTV.
Old 05-31-2013, 02:31 AM
OUCH...not ready to commit to a vent-sized hole just yet. ...wonder if these surface-mounted to the badge would work....
http://www.whelen.com/pb/Automotive/...-LED_Light.pdf
Old 05-31-2013, 08:00 AM
pbeering's Avatar
The Vertex has a bigger diameter than the LINZ6, but anything can be machined......
You might consider installing the Vertex in the front turn signal, or Whelen recently released a new flush mount head that you could mount on the bottom of the mirror.
Third approach would be to upgrade the mirrors to the newer style towing mirrors and mount a lamp in the marker light area.
Old 08-08-2014, 11:01 PM
jaygagne101194 jaygagne101194 is offline
jaygagne101194 is starting off with a positive reputation.
I noticed you used automative red tape on the back. Is it because you broke the clips? Does using only the red tape hold it to the vehicle? I have a 2006 F350 and want to do the same but without a LED installed.
Thanks.
Added some More spikes...Pics! dvldog458 Excursion - King of SUVs 57 06-04-2015 11:48 AM
Look what I found today. gangstakr 1967 - 1972 F-100 & Larger F-Series Trucks 8 08-06-2014 10:05 PM
2010 Daytona Turkey Run Photos GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 12-04-2010 09:27 PM
Stylin' the '08 mirrors! OZX1 1999 to 2016 Super Duty 59 05-27-2010 11:56 AM
Pics of progress AF Mezkin 1997-2006 Expedition & Navigator 11 01-14-2006 10:56 AM
Tags
2008, 2010, 350, badges, billet, custom, duty, f350, fender, fighter, ford, snow, super, truck, vent, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
