how to stop doors and windows from freezing shut? - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 01-02-2010, 11:37 AM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
seems like I have this problem every year,doesn't matter what vehicle I own(hasn't happened to the truck yet though). It will rain or have wet heavy snow,then the next day the temp gets down to zero or close,and the windows/doors freeze up and will not open until it warms up outside. I usually am able to get one door open,and can then get the other ones open from pushing from the inside,but the windows are pretty much hopeless until after the car has ran for at least 30 minutes,which is a pain in the butt because I hardly ever drive the car that long at one time. Is there anything I can buy to put on the window/door seals to keep them from freezing? thanks!!
Old 01-02-2010, 12:47 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Try some cooking spray like Pam or some WD40.
Old 01-02-2010, 01:12 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
^^^ Even Steve, where it NEVER freezes knows!........WD-40, Pam, Silicone lube, all will keep the moisture at bay at keep the rubber weatherstrips pliant and sealing well.
Old 01-02-2010, 01:34 PM
I thought of wd-40 or cooking spray,but wouldn't that leave a mess on the windows when I roll them up and down?
Old 01-02-2010, 01:42 PM
Old93junk's Avatar
Quote:
Not sure the config of your windows, but on mine the worst you get is a little on the extreme edges of window where it goes into the weaterstripping, nothing to worry about. I have never had trouble with the bottom edge against the window freezing up yet.
Old 01-02-2010, 02:12 PM
wycowboy63 wycowboy63 is offline
wycowboy63 is starting off with a positive reputation.
I use silicone spray on mine. Works well and doesn't leave a mess unless you overdo it.
Chris
Old 01-02-2010, 03:01 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Old 01-02-2010, 03:04 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
If you use the silicone stuff, don't get any on your paint. If you ever repaint the vehicle, that will give problems until that area is acid etched.
Old 01-02-2010, 10:12 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
I always used silicon spray on the vertical edges and on all the weatherstrips around the door. The weatherstrips rub in by hand, the windows use a rag for paint protection and spray into the channels or soak a foam Q-tip and rub/squeeze into the channel
But, if you have troubles after that, then get a marine dry lube with graphite, available at West Marine.
Old 01-03-2010, 08:00 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.fonefiddy is gaining momentum as a positive member of FTE.
Don't Use Pam, WD, Silicone. Use Maguires Rubber Conditioner. Any of the others will deteriorate the rubber over time.
I've found the best cure is to use Rain-X, and to USE a snow brush. When it snows, brush it off completely. Not just enough to see. If You get all of the snow off, it doesn't melt as You drive, and cause freeze ups.
Old 01-03-2010, 02:13 PM
jimbo beam's Avatar
jimbo beam jimbo beam is offline
jimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to behold
When I detailed cars a few years back a trick the shop manager taught us was to use liquid tire shine on all the rubber surfaces, seemed to work pretty well. We'd have 50-100 cars on the dealer lot at any time, never had a freezing problem with any of them.
I like to roll all the windows down as far as they'll go, then using a rag I soak the rubber window channel area with the tire shine, use a clean rag to wipe of the excess. Tire shine also works well when applied on the door-jam weather stripping, keeps the doors from freezing shut. Application is the same, soak a rag and apply to the weather stripping.
I like to use a squirt of wd-10 into each of the exterior door lock holes to keep them from freezing. I also soak the latch area and door hinges with wd40 to keep them from freezing too.
Like fonefiddy mentioned, remove all the snow that you possibly can from the vehicle. The snow melts as the vehicle warms up, then the newly melted snow-water seeps into everywhere and refreezes once the vehicle cools off for a long period of time, like sitting over night.
Old 01-04-2010, 10:25 PM
rywegh's Avatar
rywegh rywegh is offline
rywegh has a good reputation on FTE.rywegh has a good reputation on FTE.
I have always used Pledge at least on the door frames. It keeps the door from sticking to the rubber gasket and leaves a nice lemony fresh scent while doing it.
Old 01-07-2010, 10:51 AM
DanoFF50 DanoFF50 is offline
Former Vendor
DanoFF50 is gaining momentum as a positive member of FTE.
Fluid Film will keep your door frames and locks from freezing, and it will last a heck of a lot longer than anything else you could try. No solvents to evaporate.
Old 01-07-2010, 03:21 PM
Furyus1's Avatar
Furyus1 Furyus1 is offline
Furyus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputation
Quote:
I can vouch for the locks - It works great for them...
urgent question about pwr locks and door locks court1100f 1987 - 1996 F150 & Larger F-Series Trucks 3 11-22-2016 11:54 PM
Odd power window issue Beeler 1999 - 2003 7.3L Power Stroke Diesel 7 11-13-2016 02:15 PM
Power windows issue tycooper Explorer, Sport Trac, Mountaineer & Aviator 1 05-05-2015 05:07 PM
rear driver side door won't open rolltide3006 1994.5 - 1997 7.3L Power Stroke Diesel 8 07-07-2011 12:43 PM
93 Bronco-Tailgate/Rear Window Question Cliff Cerce 1968-2013 Full Size Vans 5 03-09-2005 05:42 PM
Tags
2000, car, cars, door, doors, f150, ford, freeze, freezing, garage, shut, stop, time, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
