What tie rods for SAS d44
I did use a drag link for a 96 f-350 and the tie rod that connects the knuckles off the 78. It is close to interfering with the crossmember as I only have 4 inches of lift. The style of the 96 is what I need but the tie rod ends are smaller where they go through the knuckle. I need one that has the same size tapered shafts on the tie rod ends as the 78. I thought maybe a F-450 might have bigger tapers. Just a shot out there though.
he has 4" lift too...
i too have low clearance between the diff and the x-member but as far as i know they haent made contact...yet...last time i tried flexing the springs were new so they had no flex to them, i tried a little bit just recently and it flexed WAY better so i might have issues now haha
794x4 The larger looking taper is off a 78 F150 the smaller is a 96 F-350. Go figure. You know how the 96 style has the two kinks to clear the crossmember on the 350s? Thats what I need with the 78 style larger tapers. Then I wouldn't have any clearance problems at all. Now when I turn real hard I might have trouble when I hit a bump. There is about 3 inches before the centerlink would hit with the wheels turned hard. I think the pics of the other 4 inch lifts here must be more like six or eight with 4 or six inch 78 era springs and the later coil buckets upping it a couple of inches.
I have looked at all the differant years except the 80 to 84 (I think). The others are the smaller size taper. I have not looked at any of the F-450s yet.
I drove the truck up and down the Interstate and it seems to drive fine. The side streets are still covered in ice and snow but it seems to act pretty good. I don't know about cross country yet but I never drive all that fast in the field any way.
I have considered getting the 4 inch or six inch 78 style springs I think I would still have good castor or could get the off degree c-bushings. The only thing I worry bout is the length of the front drive shaft.
Where is the smaller balljoint going? Does it connect the drag link to the centerlink or drag link to pitman arm? My guess is that at some point and time they have been opened up for a larger joint considering a known combo isn't working. Check a chevy one ton balljoint and see if that fits. That's a popular joint to upgrabe to. If that is no go then you will have to measure the degree of taper in there and google that taper to see what it is. There is a press in sleeve to repair worn out holes. just drill the hole to the specified thickness and press the sleeve on. You could get one that matches the taper on your troublesome balljoint to fix the problem
