1997 f250 5.4 late model - Ford Truck Enthusiasts Forums
Old 01-01-2010, 08:18 PM
dbredinger dbredinger is offline
dbredinger is starting off with a positive reputation.
auto trans stuck in 4 wheel drive.
Old 01-02-2010, 08:07 AM
highteckredneck's Avatar
highteckredneck highteckredneck is offline
highteckredneck is gaining momentum as a positive member of FTE.
you are stuck in 4wd? is it stick or push button 4wd?
Old 01-02-2010, 04:41 PM
stuck in 4 wheel dr.
Quote:
**** on dash board
Old 01-02-2010, 04:42 PM
**** on dash board
Old 01-02-2010, 05:09 PM
have you checked the relay for the t-case? could be you motor that locks it into 4wd. there has been several post here recently that has the same problem. just search for them and there was all you details about it.
Old 01-03-2010, 11:16 AM
suck in 4x4
THANK YOU . I WILL LOOK INTO THAT.
Old 01-04-2010, 09:46 PM
SteevenH SteevenH is offline
SteevenH is starting off with a positive reputation.
Are you stuck in 4high or 4low?
Old 01-05-2010, 10:42 AM
stuck in 4 high.
Old 01-05-2010, 12:28 PM
I would try 2 things. First have someone sit in the truck and you try to manually move the actuator on the differential while they turn off the 4wd. It should move out towards the driver's side when the 4wd
switch is turned off. If that doesn't work, put the truck in 4low and then turn the 4wd off and put the truck in reverse. If that doesn't work you probably have a bad motor on the transfer case, if it's getting power.
It's hard to tell without more info. Are the 4wd lights turning off but
truck remains in 4wd. That could be a solenoid or a vacuum actuator
problem.
Offroad & 4x4 351slug Offroad & 4x4 7 03-16-2013 10:11 PM
4x4. 4x4 Off Road. 4x4 Sport. fx4. 4x4 STX Irish816 Offroad & 4x4 17 05-19-2010 08:08 AM
4x4 Offroad & 4x4 5 12-09-2006 09:03 PM
celebrating holidays in schools 4x4x4x4 General NON-Automotive Conversation 28 12-16-2002 01:54 AM
1965 3/4 ton 4 door CustomCab4x4 1961 - 1966 F-100 & Larger F-Series Trucks 5 02-03-2002 02:20 PM
Tags
1997, 54, 97, drive, f250, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
