Installing an RCD Complete EGR delete, which runs for 359.99, i know a local diesel mechanic who will buy and install the full delete for 1500, is this a good price?
Full is the way to go personally, he's a great mechanic, regularly does head stud jobs, egr deletes, and head gaskets, just wondering if 1500 is a good price, he also fixing some bad leaking o-rings under the turbo at the same time for a couple more dollars
By full delete, do you mean welding the intake? Like FCDP? You can buy a full delete (Kit) from ebay sellers at reduced cost...some as low as $200. I'd buy the (Kit), pull the intake hot-wash it, rebuild the oil cooler, new intake gaskets and turbo seal/gaskets and do both the CCV filter (keep dirty air out of freshly cleaned intake and turbo) and coolant bypass (keep that freshly rebuilt oil cooler from getting clogged up). Is your mechanic going to include replacing your up-pipe with a solid one? Gets rid of the restrictive scoop.
I need to find out more, for 1500 bucks i hope so. Moyock is that what you did to your truck?
What year is the truck?The early motor is an hour or so more work to install the kit.I think something around 5 bills labor on the 03/04 is fair if it is only getting the kit put in.
I am corn-fused(sic) , if you are talking about that F350 in your sig, you need not worry about egrs and up pipes. If you are talking about a 6.0L ,state year model,they differ somewhat.
Sounds like he's talking about adding a delete (Kit)...you can have him do it or you can do it yourself. If he does it I wouldn't pay him anything more than $75 hour...or $500 max. I purchased a kit from Sinister or MKM off ebay for $250 (includes everything in Ford Truck Enthusiasts Forums - MoyockPowerstroke's Album: Sinister Diesel Full EGR Delete kit)... I also picked up an intake gasket kit $40, Turbo reconditioning kit $15, Oil cooler overhaul kit $160. I will do all the work myself in the Spring where here it will be a balmy 70*F in my driveway. My two garages aren't big enough. I will send the intake out for hot-washing at a local engine shop for $30...and let everyone know how things went (with pics).
its a 05 with 92k, never had egr problems, and i dont want them to start, i dont have the tools or the knowledge to install the egr delete, and really dont want to mess anything up,im gonna call him tomorrow to see what he does exactly.
First things first. your milage is ok ,when was it put in service. If it has not been in service for 5 years,you might rethink doing a delete before warranty expires.
