January Truck Work Thread - Ford Truck Enthusiasts Forums
British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
Old 01-01-2010, 03:31 PM
R031Kona's Avatar
R031Kona R031Kona is offline
R031Kona is gaining momentum as a positive member of FTE.
I am glad I do a lot of my own stuff! Radius arm bushings , center hinge lift brackets , beam bushings, complete front right axle replacement, rear brake shoes, right rear brake slave cylinder.........swap in a manual transfer case .....
Old 01-01-2010, 03:48 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
Why when I saw this thread did I know Andy was involved. I did all my stuff in Dec. So unless something pops up I have nothing planned. I may go outside and fire up the 66 just for something to do.
Old 01-01-2010, 04:26 PM
R031Kona's Avatar
The upside to finding out my hinge brackets were bent is that I wanted to eventually get the improved Skyjacker brackets.
Old 01-01-2010, 05:14 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
And now that can happen cause you have an excuse to do it.
Old 01-01-2010, 06:30 PM
R031Kona's Avatar
you come help?
Old 01-03-2010, 02:46 PM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
I've got a front gas tank waiting to be replaced, radius arm bushings waiting to be replaced, and front shocks waiting to be replaced. I think Santa took my motivation...
That new tv he left isn't helping either...
Old 01-19-2010, 03:48 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Put another battery in the 75. The first one I bought was no good. Sitting it had almost 14 volts. Once a load was put on it it dropped down to around 5. No wonder it wouldn't turn that loose old 360 over.
Had my tow haul light flashing last week and was going to take it in and have the codes read. Monday morning dead batteries. They are somewhat suspect as well. At this point I thought I would just disconnect them turn on the headlights and clean the connections. Drove it a bit so it could do all it's relearning stuff. So far the lights not flashing which is good but I hate it when stuff like that happens.
Old 01-25-2010, 04:56 PM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
The Pacifier
bigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputation
Well, I finally got around to changing the oil in my Ranger yesterday. Put that Quaker State full synthetic in it for the first time.
But I noticed the last time I was at Costco, where I bought the oil, there wasn't any more. Like they were trying to liquidate it or something. I should have bought more than one case. Ah, whatever, if they stock it again, I might get it.
I also did my wife's car yesterday, as it was coming due in about a week.
Old 01-25-2010, 04:58 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Speaking of due. Aren't you two getting close to baby time?
Old 01-25-2010, 05:08 PM
FORD RANGER's Avatar
FORD RANGER FORD RANGER is offline
FORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud of
im' a castrol man myself. been using that stuff for years.
Old 01-25-2010, 05:13 PM
The Pacifier
Quote:
Yep, getting close. They say 37 weeks is full term, and that's next Saturday. But the due date is still 4 weeks off.
Quote:
I've never really had any preference, but when I got my truck, Q state was the only brand I could find, so I've stuck with it. Mind you, back in the day, Q state sponsored a Buick in NASCAR, and my dad had a Buick. Might have swayed me a bit. Idunno.
Old 01-25-2010, 05:53 PM
yes they did. and my mom had a centurion.. i think it was a 72 2drhrdtp model.
so did PENNZOIL! back in the day...
Old 01-25-2010, 05:57 PM
BIGKEN's Avatar
BIGKEN BIGKEN is offline
So Little To Say!!!
BIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputation
Good evening BC!!!
Old 01-25-2010, 11:24 PM
R031Kona's Avatar
$1000 after alignment , alignment and ball joint only thing I did not do.
Old 02-08-2010, 12:56 AM
angus angus is offline
angus is starting off with a positive reputation.
I did amazingly little work on my trucks the last couple of months. The 31x10.5 tires on rusty chrome rims that I found dumped by a logging trail turned out to be the wrong bolt pattern. I wanted to use them to check if 31x10.5 tires would fit a stock '57-'60.
I did some ghetto body repair on an '80s Toyota Tercel. The rust around the rear wheel tubs and quarter panels was so bad that water was splashing in and soaking the carpets. So, I used up some old marine body filler, spare roof patch fabric, then roof patch compound since it was easier to work with. The gaping holes in the bottoms of the rear quarter panels I filled with spray foam. And I replaced one door switch (the original was badly corroded so the wire broke off) so now the courtesy light works again when unloading the back seat.
This month: hopefully triage the remains of the '60 M100. Save the good parts, recycle or chuck the hopeless. Fix an air compressor so I can sandblast the '59 frame and panel truck seams when the weather warms and dries up.
I have far too much time on my hands right now, and I know I'll regret not making better use of it when I'm working full-time again.
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
