1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Need brighter headlights...what's the best option?
Old 12-31-2015, 08:09 PM
browntown3's Avatar
browntown3
browntown3 is offline
Hey guys, own a 2000 expedition...have a hard time seeing at night, probably one of the worst headlight output out of any vehicle I've owned so am looking for some brighter options. First off I have the factory lenses which do have a little hazing but have cleaned a few times with renewal products....I have silverstar ultra bulbs and run foglights on when headlights are on dim which do very little to help..... have any of you found a good option such as another type of lense or another type of bulb to help? Looked on Amazon and found the "ford lightning" style lenses that am thinking of trying but wanted to see if any better ideas might come from you guys.....thanks in advance
Old 12-31-2015, 08:41 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Get it checked out ASAP. Gotta be something wrong, electrically.
Old 01-01-2016, 09:43 AM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
Old 01-01-2016, 11:01 AM
browntown3's Avatar
browntown3
Originally Posted by alloro
Did you use the stock lenses or "housing" for them as just a plug and play? This is kind of what I'm looking for!
Old 01-01-2016, 12:30 PM
alloro's Avatar
alloro
alloro is offline
All I did was remove the existing lamps and plug these in their place. Keep in mind they only fit in one way into the housing just like the original lamps. Also be sure to fan out the braided heat sink before installing, it's just easier that way. I also adjusted my headlights down about 5-10 degrees afterwards. Being brighter...doing so keeps you from blinding oncoming drivers plus it lit up the road better. Forget about the high beam function because all it does is light up the trees and you won't need it anyway.
Old 01-01-2016, 02:40 PM
Skauber's Avatar
Skauber
Skauber is offline
Hows the beam scattering compared to the oem ones? I've been contemplating hid or led, but in a projector as im worried about light scattering and blinding others
Old 01-02-2016, 12:17 PM
alloro's Avatar
alloro
alloro is offline
Very similar.
Old 01-02-2016, 12:25 PM
blackex's Avatar
blackex
blackex is offline
Go with a clear aftermarket headlight housing and upgrade to either LED bulb or HID for drastic improvement.
Old 01-04-2016, 07:55 AM
5.4T's Avatar
5.4T
5.4T is offline
Old 01-06-2016, 06:54 AM
Travis S's Avatar
Travis S
Travis S is offline
+1 here. Sounds like voltage drop from the switch having too much current being drawn through it. Adding in relays for it would help considerably by giving the lights a new power feed and reducing the load on the switch to a 1-2 amps in the worst case scenario.
Alloro, those LED bulbs look great and draw half the current of regular 9007s, sounds like the perfect solution. I think I'll be getting a pair of them next
Old 01-06-2016, 09:39 AM
alloro's Avatar
alloro
alloro is offline
If for no other reason they really light up street name signs at night. I used to squint to read the signs, now I see them from 2 streets away.
Old 01-06-2016, 03:55 PM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
Alloro - No flashes from oncoming cars with the slight downward adjustment?
Old 01-07-2016, 09:54 AM
alloro's Avatar
alloro
alloro is offline
The only time I got flashed is when it was raining out and the roads were wet. As I'm sure you've witnessed, when roads are wet the light reflects off the road and makes oncoming headlights appear brighter.
Old 01-07-2016, 11:25 AM
alwaysfords41
Thanks, I'm willing to invest to try them out.
Juanito
2017+ Super Duty
51
08-19-2020 07:17 AM
darrellbarnes
05-24-2019 11:34 AM
bronco1983durango
2009 - 2014 F150
06-05-2015 10:57 PM
DavenTn
03-23-2014 08:24 AM
superdutyranger
2009 - 2014 F150
25
02-08-2010 12:20 PM
Quick Reply: Need brighter headlights...what's the best option?
