78 F100 302 Vacuum Hoses
Old 01-01-2010, 01:27 PM
78_F100's Avatar
78_F100
78_F100 is offline
Replaced head gaskets and didnt mark the vacuum hoses when i did it now i need some insight or a diagram for the egr valve hoses
Old 01-03-2010, 12:18 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
EGR runs from a temperature-switched ported vacuum source. In most cases, a vacuum line goes from a ported vacuum source on the carburetor. If you're using the stock carburetor, there should be a port near the driver side idle mixture screw. That hose runs to one of the ports on the ported vacuum switch near the thermostat. It doesn't matter which port. The other port of the switch runs to the EGR valve.
berry1234
09-18-2015 09:46 PM
markeyd
08-10-2015 09:41 AM
David Wogen
02-20-2014 05:16 AM
78 & 87 Super Cab
01-15-2013 09:04 PM
chizzy matt
07-07-2012 06:11 PM
Quick Reply: 78 F100 302 Vacuum Hoses
