Throttle Body Cleaning - Ford Truck Enthusiasts Forums
Old 01-01-2010, 01:51 PM
pb34's Avatar
pb34 pb34 is offline
pb34 is starting off with a positive reputation.
I tried searching for a thread with specifics on cleaning the throttle body but I couldn't find one. I know it is a good idea to clean the throttle body every once and a while and I have around 40k miles and figured it would be a good idea to do it now.
Is there anything that I should be careful of while doing this? Is there any specific way to clean it or any cleaners to use? I just don't want to mess anything up while doing this. Any help is appreciated! Thanks!
Old 01-01-2010, 02:21 PM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
make sure the cleaner says it is for throttle bodies
put rags or towels under/around the open end to keep from over spraying or dripping onto other parts etc ...NOT good for rubber/plastic/paint
use an unpainted wooden dowel (not plastic and DEFINATELY not metal) to hold the throttle body plate open (at the bottom side)
expect the truck to be rough and make you think you ruined it when you restart...sputtering, check-engine light, etc
after about 30-60 secs, shut off the engine then restart and all will be fine.
Old 01-01-2010, 09:59 PM
pb34's Avatar
Alright so it's that simple? Any good cleaners that people like?
Old 01-01-2010, 10:10 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
truck shouldn't react at all...if anything, it should run smoother.
I used rubbing alcohol (no no...but all I had at the time) to clean it. used a clean lint free shop rag
basically soak the rag with your cleaner of choice...to be honest, I think anything would be fine as long as you keep it only on the metal.
also make sure to clean the upper/lower sides of the TB plate.
when I did mine, it was absolutely filthy. @ 23,000 miles. There was crap caked on the edges of the butterflys, and a decent layer on the whole thing.
Old 01-01-2010, 10:27 PM
60DRB's Avatar
I'd bet they all use the same chemicals. I shot about half a spray can through mine while the engine was off. That may be why it was so unhappy on the first start-up. I didn't have anybody around to mash the gas while the engine was running...
Old 07-11-2010, 07:37 PM
geogman2 geogman2 is offline
geogman2 is starting off with a positive reputation.
I took the throttle body off and cleaned it. It was real easy to do, only took 1/2 hours or so. I did it while changing my plugs.
Old 07-11-2010, 08:12 PM
tolliewolly's Avatar
tolliewolly tolliewolly is offline
tolliewolly is gaining momentum as a positive member of FTE.tolliewolly is gaining momentum as a positive member of FTE.
Where is it? I would like to clean the one on my 4.6 ford. Any instructions on how to do it?
Throttle Body Cleaning GadgetGuy22 1997 - 2003 F150 9 05-26-2016 01:03 PM
one spark plug & one engine question Stebman Ranger & B-Series 9 03-09-2015 09:27 PM
No throttle response tankeryanker73 1999 to 2016 Super Duty 10 07-01-2010 03:43 PM
How To Properly Clean Throttle Body? SeannyBoy84 Modular V8 (4.6L, 5.4L) 8 09-12-2005 04:25 AM
High Idle after Throttle body cleaning JTD1972 1978 - 1996 Big Bronco 11 06-18-2003 08:16 PM
Tags
06, 2004, 2006, 54, body, clean, cleaner, cleanig, cleaning, expedition, expeditoin, f150, ford, iac, miles, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
