Rear Axle Ratio...how do I know what I have?
Old 01-01-2010, 10:52 AM
Michael Hopton's Avatar
Michael Hopton
Michael Hopton is offline
My new to me 03 EB Exc 4x2 is equipped with the factory towing package. I'm not towing that much - a 4500lb max weight popup camper. How can I determine what the axle ratio is in the rear end of my truck? Oh, it is a 5.4l v8 - and no, it doesn't win a drag race - but it sure moves quickly enough for hauling my family around safely!
thanks...
Old 01-01-2010, 11:12 AM
howler4x4's Avatar
howler4x4
howler4x4 is offline
Post the info from the tag on the diff
or
search here for VIN # decode info
Both of the above assume that the ratio is still matches the tag/VIN. 100% sure method is to count teeth; prolly overkill for your purpose.
Old 01-01-2010, 11:22 AM
gr8scott72's Avatar
gr8scott72
gr8scott72 is offline
or
Even easier than that:
If it's close to this:
Then you have 4.10:1 gears.
If it's below 2k rpms at 60 mph, then you have the 3.73:1 gears.
Old 01-01-2010, 05:10 PM
Immortal_Ben's Avatar
Immortal_Ben
Immortal_Ben is offline
Yup, I have the 4:10s and that looks about right.
Old 01-01-2010, 06:14 PM
gr8scott72's Avatar
gr8scott72
The picture is from mine and it is the 4.30:1 but the OP has the V8 so it would be the 4.10:1 instead. (or 3.73:1)
Old 01-01-2010, 07:05 PM
Immortal_Ben
I said "about"
Old 01-01-2010, 08:02 PM
UrbanXX's Avatar
UrbanXX
UrbanXX is offline
If you want to know your "rear axel" look in the drivers door jam:
You will see an axel code
If your axel code begins with a LETTER you have a posi rear-end
Get the axel code and look up the code for ratio.
Your Excursion being 2WD with a 5.4 engine should have a 4:10 if the axel code starts with a letter then it should have a posi-track rear end, if not a standard 4:10 rear end. Unless it has been changed over the years.
There are exceptions but few.
Old 01-02-2010, 01:04 PM
Michael Hopton
My axle code is "31"
At ~60-65mph I'm turning just under 2k rpms - 18-1900 or so.
Don't think anything's been changed - vehicle is all stock. What is better for towing? 3.73, or 4.01? Does it matter too much if my fully loaded pop-up is no more than 4500lbs?
thanks
Old 01-02-2010, 03:24 PM
UrbanXX's Avatar
UrbanXX
UrbanXX is offline
Axel code 31:
3:73 NON Limited Slip.
Old 01-02-2010, 03:33 PM
Michael Hopton
Which means...?
Old 01-02-2010, 03:35 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
You have a 3.73:1 ratio axle and you do not have a limited slip (traction device) installed.
4.10s would be a better match for your truck (IMO) but sounds like things are working out for you as it is now.
Old 01-02-2010, 03:38 PM
UrbanXX's Avatar
UrbanXX
UrbanXX is offline
It means your Ford Excursion has an axel ratio of 3:73 to 1. It also means that your Ford Excursion does not have a limited slip rear-end.
Old 01-02-2010, 03:41 PM
gr8scott72's Avatar
gr8scott72
I also means that as long as you are happy with the way it tows, save your $750 and keep driving it the way it is. (Regearing costs about $750 per axle to have a quality shop do it.)
Old 05-22-2012, 03:17 PM
Nof1's Avatar
Nof1
Nof1 is offline
Hi everyone .. I need ur help .. I have 01 v10 x limited with towing package the tag on the inside of my door say axle e ... What size gear does that mean??? Thank you for your
help
Old 05-22-2012, 06:12 PM
ComputerCowboy's Avatar
ComputerCowboy
ComputerCowboy is offline
help
An axle code is supposed to be two characters. Are you sure it only says E?
I called my local dealer with my VIN and they looked up my axle for me.
Quick Reply: Rear Axle Ratio...how do I know what I have?
