Magic Air Heater Cores - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 02-16-2010, 09:04 AM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
Hello all, sorry it took so long for me to get the PM and get back to you on my install. It's been a couple years now sense I installed that Core in my Magic Air. I did cut the tubes back as much as possible and soldered the 90's on. I took a round file and elongated the tube holes towards the end of the housing. I wanted the tube end of the core to sit tight against the housing so there wouldn't be a lot of pressure on the tubes. Yes it was a tight fit, I just crammed it all together and have been using it without any problems sense that time. I wasn't super concerned with preservation of the heater housing as I haven't restored my 51 back to stock. It's my daily driver and I was only concerned with heat and having the defroster working. I imagine there are better options in core selections out there, but I spent $29.00 for that core and wasn't interested in spending more to have the end core (tank) installed off the old one. Had I been going to spend that kind of money I would have bought a Vintage Air unit and sold the Magic Air. Years ago Back in the 70's I cut the fins out of a 66 Bronco heater core and soldered the leaking tube up. It worked fine for the rest of the time I owned that 4X4. I would have done that to the 51 core but it was full of sludge.
Hope this helps
Rod
  #62
Old 02-16-2010, 03:32 PM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is offline
BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.
Thanks for getting back with us, Rod. That certainly helps clear up some of the confusion. I'm still working on finding a solution that doesn't require modding the housing, but I've been busy with other things lately. All in good time!
  #63
Old 02-22-2010, 01:54 PM
thechassisman's Avatar
thechassisman thechassisman is offline
thechassisman is starting off with a positive reputation.
Don't be afraid to take this heater apart. I have had a lot of this stuff, the 51 tubes and matching holes in the back of the housing that they go through, are farther apart than the 52 model. also the other posts have the photos of the 51 and 52 emblems correct, the 51 is lightly etched and filled in with paint, and the 52 is totally different and deeply embossed. If the tabs are broken off of the emblems there is a good fairly easy fix I have come up with for that. One other thing is that if you have a 51 and a 52 outside duct elbow in your hands, you will see that the difference is that the 52 elbow duct will have a flange that goes all the way through to the inside for the rubber duct connector to go on, and doesn't use the round backing plate with the round type inside metal flange like the 51. All can be seen in the Chassis part catalog pictures if you look closely. So the outside metal elbow ducts of course have different part numbers.
_____________________________________
1950 1952 1955 V8 Marmon Herrington Rangers
Mark
  #64
Old 02-22-2010, 08:03 PM
Quote:
Originally Posted by Julies Cool F1 View Post
I think BOR is going to put it all together into a "Tech" along with the duct info and the motor info.
If not, I have saved all those threads as we build them and will keep them together for the next time this comes up - never has before, so this is good!
Julie I did a little research and found this Co. Fasco - DC Motors
Hope it helps Mark
1950 1952 1955 V8 F1 Marmon Herrington Rangers
Mark
  #65
Old 02-23-2010, 01:04 PM
Good luck with your projects
  #66
Old 01-05-2013, 04:22 AM
1930 Dodge 1930 Dodge is offline
1930 Dodge is starting off with a positive reputation.
This was another good series of posts but again it does not appear ( unless I am missing something ) that a direct replacement motor was found, single speed motor yes but originally mine was dual speed which I would like to retain and the original motors ran in a CCW direction which will affect air flow.
Does anyone have any addit. info that might help with getting a correct motor?
FYI: Heater core for factory A/C Bumps now available Norton72 Cooling, Heating, Ventilation & A/C 2 12-26-2016 04:02 PM
More Gratuitous Parts Porn! BlueOvalRage 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 09-15-2011 08:25 PM
Holy Magic Air heaters firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 05-01-2011 12:12 PM
F-2 Flatbed Ideas BlueOvalRage 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 11-08-2009 12:28 PM
51-52 Heater Comparison BlueOvalRage 1948 - 1956 F1, F100 & Larger F-Series Trucks 41 11-05-2009 09:44 PM
Tags
air, d5uz18476c, dodge, ford, fresh, heater, id, kick, magic, make, numbers, panel, radiator, ram, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
