Magic Air Heater Cores - Page 2 - Ford Truck Enthusiasts Forums
Old 01-02-2010, 01:06 AM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is offline
BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.
Tim,
That number did sound very promising. So much so that I swung into Autozone tonight and inquired about one. Lo and behold, they had one on the shelf! I stopped back in later on with my core and rear housing to see how it would fit. The width was dead on at 7 3/4", but even though the catalog lists it as 8" long, this one measured 8 1/4". It would almost fit into the housing, but all 4 corners of the core rub the housing and it would have had to be forced into place. The one they had was a Proliance/Ready-Rad brand. Perhaps a different brand would be the correct 8". I'll be looking next week to see if someone else locally can get a different brand. The tubes are also off a bit. They would somehow have to be offset about 1/2" on one side and 3/4" on the other for a '48 - '51 case. Large offsets are easy, but small ones like that might be a problem without kinking the tube. Most anything will need the tubes modified for a '52.
Quote:
Could I get some credit for the 2 restored Magic Air heaters in the above link ?
Denny,
Sorry we gave credit for your work and pic to somebody else! BUT! Now that we have your attention, can you tell us what you used for a 12V heater motor and also if you replaced either of the heater cores? If you did, what part number did you use and did it require any mods?
Ilya,
After taking my 1952 heater apart, it was clear to me that it had never been out of the truck before and had never been apart. It had been spray bombed black in-situ under the dash, but was originally a dark silver hammer-tone finish. The original part number and date of assembly was painted on the back of the heater over this finish and the inside is the same color, so I'm certain of that. I need to get pictures taken of that. But that doesn't mean that they weren't a different color in prior years. Obviously, the badge and some other details changed, so the color might have also. If we can nail the colors of the different years down with certainty, this should be documented, too.
Also, it's good to know that you've got someone available that can work on the cores. I haven't given up on finding a close replacement yet, but it may come to pass that the only viable option is to either move the tubes on a readily available core or swap the OE tank onto a different core. It would be great to have a go-to guy to get this work done. Perhaps you could get a few done and keep them in inventory??
Old 01-02-2010, 01:23 AM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
BOR Sure .why not just ask for the info instead of ganging up on me with the wrong pic /alot of work credit on the 2 Magic Air heaters to get my attention ? JJ= Just joking !!. I took the gamble and purchased the 12 V heater motor from SVF . It fit /worked fine . I did not have to replace either heater core . I like your line of thinking on using the new core and swapping the tank portion . Seems like the lesser of two evils to me . Good luck and Happy Safe New Year to all . I hope all of us get a ton of work done on our trucks in '10
Old 01-02-2010, 09:56 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Would these work?
7-3/8"W x 9-3/8"L x 2" thick, overall dimensions. These are for a '93 F-150, and they only cost $26 at AutoZone. The tubes would be easy to modify.
Old 01-04-2010, 05:26 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
BOR asked me to contribute anything I have on the heaters. Here it is:
A stock heater unit out of '48-50:
The color I have found on the back side of all the units I have is silver hammertone that you can buy in almost any store now. When I did the one in my F-2 15 years ago I could only find it one small neighborhood hardware store.
These are the drawings I have out of the Ford truck parts catalog, I don't know if any one has posted these, I didn't have time to look through all of the pages on thread:
I've had numerous '48-52 trucks and the heaters were pretty consistent with which heaters went with the corresponding heaters in the drawings. The cab I used for my '49 F-2 is from a '48-50 F-7 firetruck and when I got it it had the heater unit from a '51 or '52, I assume it was a while after the truck was originally bought by the fire department.
Old 01-04-2010, 09:15 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I'll confirm the silver hammertone.
I went by my storage locker yesterday and unpacked a heater that I bought a few years ago on eBay.
Here it is.
It's marked as a 51 by the prior owner. However, looking at the boot, it's round, so it is a 51 like Julie pointed out. Also, the Magic Air trim in the front is a 51 (???) if our assumption is correct.
Old 01-04-2010, 09:26 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
That's a 51 boot Ilya - first one I've ever seen. 52 Was the square one on the intake side! So, it's consistant with a 51 heater/install.
Old 01-04-2010, 10:10 PM
jmadsen's Avatar
jmadsen jmadsen is online now
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
Great post and info! Thanks
I just looked at my 52 & 51 magic air heaters again and I'm sure I may be needing to refer back here at some point in the future.
Especially on the 51 heater. it was damaged in shipping and the bottom tube is bent, maybe it will straighten out ok though? also the 52 Script motor cover matches the above descriptions only I found mine inside the glove box inside a mouse nest and they had been urinating on it so when I cleaned it up those areas just turned to dust I hate mice
Old 01-04-2010, 11:57 PM
Thanks to Bob and Ilya for pitching in. It looks like all of the fresh air heaters were originally hammertone silver or dark gray. I'm still playing with heater cores, although it isn't looking too good for finding anything that will drop in without much effort in my '52 heater. I haven't given up yet, but after reviewing 400+ cores in a catalog a couple different times, it isn't looking too promising. There are other possibilities in the works, though. Some sort of replacement core should eventually come out of this.
Old 01-05-2010, 12:36 AM
51PanelMan's Avatar
Quote:
You're right, Julie. I've edited my post to reflect the same.
I transposed the two pictures that Bob posted without double checking the diagrams too closely.
Quote:
You're doing a great job! Eventually, a replacement core will be found whether it's a direct drop in or needs to be modified. Let me know if there's anything I could to help once you find a comparable core.
Old 01-05-2010, 12:46 AM
HD74's Avatar
HD74 HD74 is offline
HD74 is gaining momentum as a positive member of FTE.
This is great info and how your all pulling it together, well done... Can't tell you all how many times I read a lengthy thread that just leave you hanging.
Old 01-05-2010, 02:49 AM
Stand by Marty, it's coming.
There will be concise conclusions on all three areas of the heater write ups that are going on. Cores, Motors, and Ducts. Be patient, up until now there wasn't this much interest in them. So, to take a few weeks to find the right answers with NO prior documentation is actually pretty amazing.
Old 01-05-2010, 08:18 PM
firstrider's Avatar
Ilya ,that is a '51 heater boot .Have 6 next to me in the stock drawer . Can make as many as needed . '52's are the same at the heater end but are 3 & 7/16 wide x 2 & 7/8 tall at the kick panel inlet . Have 5 of them in the drawer also and can make many more . The repro 10 inside buck and the carbon fiber outside of the mold does not wear out .
  #28
Old 01-05-2010, 08:28 PM
So Denny, you're making both 51 and 52 boots right?
  #29
Old 01-05-2010, 08:49 PM
firstrider's Avatar
Boots
Yes , Julie that is correct .Will try to post a pic of each . Called SVF today & inquired about the heater motor . Narrowed it down to 2 models . Now I 'm not sure if mine will work .So will get it out of the box. put some elec. to it and see what happens . Also will take it apart and check the part # .Stay tuned for more details .Later ,Denny
  #30
Old 01-05-2010, 10:49 PM
firstrider's Avatar
Heater boots
'51 heater boot . Will fit '51 F-1 & up trucks as well as '51 & '52 Merc trucks M-47 & up .
Yr specific .Will only fit '52 Ford F-1 & up trucks . Correct durometer ( hardness 80 ) , cast lines in all the correct places , snug fit . Will fit perfectly .
FYI: Heater core for factory A/C Bumps now available Norton72 Cooling, Heating, Ventilation & A/C 2 12-26-2016 04:02 PM
More Gratuitous Parts Porn! BlueOvalRage 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 09-15-2011 08:25 PM
Holy Magic Air heaters firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 05-01-2011 12:12 PM
F-2 Flatbed Ideas BlueOvalRage 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 11-08-2009 12:28 PM
51-52 Heater Comparison BlueOvalRage 1948 - 1956 F1, F100 & Larger F-Series Trucks 41 11-05-2009 09:44 PM
Tags
air, d5uz18476c, dodge, ford, fresh, heater, id, kick, magic, make, numbers, panel, radiator, ram, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
