Air Filter/breather thumping when cold - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-31-2009, 09:57 PM
koboss1's Avatar
koboss1 koboss1 is offline
koboss1 is starting off with a positive reputation.
Anybody else notice this tumpthump thump tatatata on take off from the passenger front like it is right below the windshield? only thing i can tink off is the air breather snorkel banging, seems like ever since the air filter message came on during snow storm.
is it just me or do you guys get the feeling the service people dont believe we hear these kinds of things...
Koboss
Old 01-01-2010, 07:29 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
service people do not beleive anything but a check eng light or a code nowadays. The time of trouble shooting is left to us it would seem.
I never heard of your thumping sound before from anyone. Did you pull the filter, check everything for proper placement and tightness? That would be the only thing I can recommend at this point.
Old 01-01-2010, 07:42 AM
ruschejj's Avatar
ruschejj ruschejj is online now
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
I get the same thing under heavy loads. I have tried to get responses on other threads here by describing it as a sound you could make by popping your hand on the vacuum hose while it's running.
It has not happened to me in a few weeks and I have no idea what it is. Wish I did. Did not go away with a new air filter, the restriction gauge never moves as a result of this popping either.
And I also agree, people look at us as if we just landed from Pluto when we try to describe some of the quirks we encounter.
Old 01-01-2010, 07:45 AM
senix's Avatar
I wonder now that we are talking about it (well typing), every once in a while from take off, usually could I get what I would call a turbo fart, is that what you are hearing?
Old 01-01-2010, 08:39 AM
ruschejj's Avatar
It could be but I don't have enough experience with diesels to know what that sounds like. The Dmax I used to drive never made any sounds. My diesel history is '02 Dmax, '08 6.4PSD.
Old 01-01-2010, 08:40 AM
senix's Avatar
turbo fart to me sounds like it is kinda going in reverse because of too much pressure.
Old 01-01-2010, 11:08 AM
koboss1's Avatar
thanks guys i feel better knowing that, its not a turbo fart i had that with my 6.0 so i know that sound i got it on my you tube site...i will check air filter for tightness
Old 01-01-2010, 04:00 PM
Gearitis Gearitis is offline
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
I just picked up a 2008 6.4L Lariat 10 days ago and I noticed the same thump, thump, etc, its under warranty so I took it in. They pulled up a TSB that indicated it was due to a heater/vent door sticking and causing it to release with excessive force. So as it cycles, moving air, or recirculated air, it would thump, thump etc. It took them an afternoon but they fixed it. Might look into that!
Old 01-01-2010, 07:40 PM
senix's Avatar
i had thought about that tsb but didn't think the description fit. But worth an idea.
Old 03-31-2010, 01:21 PM
Jake4809 Jake4809 is offline
Jake4809 is starting off with a positive reputation.
I have a similar thumping sound on my 08 SD, could not find the TSB. Anyone know the TSB number?. Thanks
Old 04-01-2010, 09:41 PM
ronnie jr ronnie jr is offline
ronnie jr is starting off with a positive reputation.
is the noise there all the time
Old 04-01-2010, 09:44 PM
i just fixed a 2006 f250 with the same noise it was a broker roker on #8 exaust
Old 04-01-2010, 10:16 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Turbo fart is my guess.
Fix with Italian tuneup.
Old 04-01-2010, 10:29 PM
forddieseldoc forddieseldoc is offline
forddieseldoc is starting off with a positive reputation.
tsb 09-4-1 is for the a/c compressor engagement thump. repaired one today by replacing the sucction accumilator (dryer). this is mostly heard at idle as the a/c compressor cycles.
Old 04-02-2010, 06:55 AM
ruschejj's Avatar
Thanks for the info forddieseldoc, but, the thumping pop-pop-pop sound happens under hard acceleration with a heavy trailer or just without a trailer and special weather circumstances. Generally really hot days, sunny and humid for me. The engine's power really hits a "wall" sometimes. Prob some kind of safety.
starter intermittent grinding koboss1 6.4L Power Stroke Diesel 7 12-08-2010 02:37 PM
Loud thumping out of intake iron1951 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 28 09-16-2010 07:47 PM
FYI trailer lights have fuse koboss1 6.4L Power Stroke Diesel 10 05-11-2010 10:23 PM
Check Air Filter Message? koboss1 6.4L Power Stroke Diesel 15 12-18-2009 09:42 PM
Cracked Fuel filter cap, Top of engine need new? koboss1 6.0L Power Stroke Diesel 5 03-20-2009 08:07 PM
Tags
42l, 64l, acceleration, air, breather, coming, engine, filter, ford, gauge, noise, popping, pops, restriction, thump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
