Rear Heater Not Working - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 12-31-2009, 07:41 PM
ianobetz ianobetz is offline
ianobetz is starting off with a positive reputation.
I just purchased a pretty nice, older ford E-350 superduty van. It has rear AC/Heater. The front heater works great, but the rear heater does not blow hot air, just cold. There's no place to adjust the temperature on the rear heater (it runs off the front controls).
The Haynes manual doesn't go into the rear heater too much, so I was looking for some direction. Does anyone have any suggestions on where to start my diagnosis?
Thanks for your help, Ian
Old 01-01-2010, 12:15 PM
Update:
I did some snooping around in the rear heater... The condenser in the back is getting hot, but there's no air going through the intake to pass through the condenser. I'm not sure how to get in the compartment to check things out though.
Old 01-01-2010, 01:17 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Turn on the rear fan for a start.
Make sure that the Front control is on "Heater".
NOT AC.
Old 01-01-2010, 03:32 PM
Well... I guess I asked for a place to start didn't I? Thanks gearloose1. At least you didn't tell me to open the door, insert key into the ignition and start the engine.
I've gotten to the blower motor in the back. It seems that when I turn it from cold to hot on the thermostat, the door inside the blower assembly doesn't switch from A/C to Heater. The vacuum line looks like its in good shape, but makes no sound when turned from cold to hot. Has anyone run into a problem like this?
Old 01-01-2010, 04:01 PM
More troubleshooting resulted in getting the heater to work by disconnecting the vacuum line that goes to the blend door actuator. When I disconnected it, the door opened right up and switched from AC to Heat. So no matter where I the thermostat is on the panel, the vacuum line is keeping the heater door closed. Sounds like an instrument panel issue. Any help from here?
Old 01-01-2010, 04:44 PM
Vacuum control switch on the front panel is the next place to check.
Find out why it is not delivering or shutting off vacuum.
Is the line normally on (vacumme) or off (no vacuum)?
If you can find the routing... sometimes, the line is kinked... or alternatively, plugged.
Compressed air carefully used can help --- be careful not to damage anything using too high a pressure...etc...
Do you have a kinked line?
Check that first.
Then check the dash switch and see if the line is pulling vacuum...
Old 01-28-2010, 10:27 AM
getout getout is offline
getout is starting off with a positive reputation.
Did you end up figuring out what was wrong? I've got the same problem in a van I just bought. Haven't gotten into it yet but now that I've got a place to start I might get it pulled apart over the weekend.
Thanks!
Old 11-08-2013, 02:59 PM
Joseph Luke Plotts Joseph Luke Plotts is offline
Joseph Luke Plotts is starting off with a positive reputation.
I have the same prob with my e150.....any solutions?>???
Old 11-08-2013, 03:03 PM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
Do you have a Club Wagon or other high trim level van---or is your rear heater assembly uncovered?
Old 10-21-2014, 12:55 AM
E350_traveller E350_traveller is offline
E350_traveller is starting off with a positive reputation.
hi guys,
i have the same Problem. I have a '92 E350 7,3l Diesel
I found an open connection of the vaccuum at the right side of the heaterbox in the front but i cant find the hose which seems to fit in there.
It seems, that the hoses which go into the rear heaterbox are not getting warm.
any suggestions?
Old 10-21-2014, 06:06 PM
ligito ligito is offline
ligito is starting off with a positive reputation.
Can you disconnect the vacuum hose at both ends and blow low pressure through, to clear any obstructions?
Old 10-21-2014, 11:19 PM
I disconnected the blue vacuum hose in the back today and then there was air blowing only on the floor and still cold. I connected it back and in ac and venting mode it was blowing on top again.
Then i checked the vaccumhoses in the front. looks like this. four connections are open, but there are no more hoses to connect.
is there somewhere a valve i can check? i could not find the heaterhoses for the rear in the motor compartment. i only found the a/c hoses.
ACin the back is working also when there is warm air in the front
Old 11-11-2014, 06:29 PM
Would it help, if you plugged the open ports?
Old 02-24-2015, 09:17 PM
Hi guys sorry for coming back to this this late.
I found out why its not working. Somebody disconnected the hoses of the rear heater right at the motorblock. Seems like there has been a former problem with a leaking heater or something.
Heater Control Valve Question jasonodsky Excursion - King of SUVs 15 07-10-2016 09:09 PM
Rear heater coolant line leak reospw Excursion - King of SUVs 1 04-18-2016 08:28 AM
2000 Navigator heat issue thurston 1997-2006 Expedition & Navigator 5 11-26-2015 12:13 PM
2002 X with heater stuck on in the front Az2008f350psd Cooling, Heating, Ventilation & A/C 1 01-15-2012 07:56 AM
Rear Heater Issue gvincEX Excursion - King of SUVs 2 02-26-2010 10:08 AM
Tags
2000, 2004, 2006, e350, ford, heat, heater, hot, motor, rear, switch, truck, van, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
