Rear end gear change- your opinion
on
Fords name for their factory limited slip differential is the Trac-Lok, it's a clutch loaded unit that can deliver near locker performance when setup correctly but is totally smooth and silent in operation compared to a real locker. They're relatively cheap to buy new and plentiful in junkyards too.
I agree with going with the 4.10 gears since you have 31s. Also get a traction lock or similar limited slip diff. It can be rebuilt. I have one and think its great. Auburn also makes a good one.
I won't ever own a true locker again. I don't think its a good choice for a daily driver. Its more suitable for a mud truck or drag vehicle.
depends on what year and what tranny. on my 92 with a E4od the sensor is in the rear end and automatically adjust for the gear swap. like i went from 3.55's to 4.10's. and i had to change nothing. and the speedo is still dead on accurate. now on older C6's there is a speedo gear in the tailshaft of the tranny and you have to change that cause it changes the Rpms of the output of the tranny and i think on the new ones like after 86 or so there are 2 spots. the rearend and the tailshaft i think probably wrong. i believe the M5od is the same setup as the C6 but may be wrong bout even the C6 setup.
The 92 and up F-trucks use electronic speed detection on the ring gear so the computer couldn't care less what gear ratio the rear axle has nor what gear you're in transmission wise - the only thing that will confuse it's ability to detect speed is tire diameter. Larger tires give a false reading of "slower" than actual, smaller diameter tires give a false reading of "faster" than actual.
The cluster is also programmable so you can change your tire diameter five times before the cluster won't allow you to change any longer.
Since the original poster has an 87, his speedo is connected via cable to the transmission, so rear end ratio changes and tire diameter changes impact it's accurancy.
I really don't know why you wouldn't just select 3rd instead of overdrive. It's obviously easier to do than changing out the ring and pinion. If you tow constantly, then 4.11 gears would be the way to go. But for a one-off or occasional/seasonal towing, I'd just avoid overdrive.
How do you know what speedo gear to get? Like in my case, I have the M5OD, 3.08's, and 31-10.50-15; if I went to a 4.10 gear, what speedo gear would I need, and where would I buy it?
nomax1955
1999 to 2016 Super Duty
04-26-2012 12:35 PM
cartmanea
09-30-2009 04:33 PM
