Why does the Dodge 8.0L V10 get such a bad wrap?
#46
#47
The following users liked this post:
#48
Well yes and no. The bore is the same as the 360. The blocks are a little different. The 8.0 had the oil pump mounted on the front of the crank. The block also extended below the crank too for added strength. The heads shared alot of the same components as the 360 though. This motor was pure genius. 450 ft lbs of torque was pretty inpressive back then. And still very respectable now as far as gassers go. They sounded like a v-6 though. My Ford v-10 sounds like a indy car when u twist it. I love it!
#49
Incorrect Krewat, the truck V10 is a modified Viper V10 recast in Iron. The only thing the Truck V10 has in common with the 5.9 V8 is bore diameter.
For example, the truck V10 uses a crank mounted oil pump, is a deep-skirt block like the Viper V10 (The 5.9 is a short skirt block with a distributor driven pump). Those changes alone should essentially qualify it as an entirely different engine. The engine is also much more advanced in that it uses camshaft/crank position sensors, is distributor-less, etc...
#50
#51
No crap the Viper and Dodge V10 are different, one being cast in aluminum and one being cast in iron. I'm saying the Truck V10 has a lot more in common with the Viper V10 than it does the LA/Magnum 5.9.
You're also wrong on the crank. Both the Viper and Truck V10 use shared-pin cranks, with un-even firing orders. The Ford V10 uses a split-pin crank to even out the firing order, but needs a balance shaft.
Do to the firing order of the Viper V10, what you're basically hearing is two 5-cylinder engines. Very, very different sound than a V6. The Ford V10 with its even firing order has a very different sound.
The Dodge V10 has a very deep, throaty growl because you are essentially hearing two fairly low-revving 5 cylinders. The exhaust pulses on the Ford V10 work together better giving it a high-strung racey exhaust note. I personally prefer the 5 Cylinder sound.
#52
#53
Like my Ford trucks and race a ford truck but a couple years ago had to find a 3/4 ton truck quick and ended up with a 1996 ram 2500 ext.cab lb v-10, and other than mileage it is a total horse. power to pull anything, quiet, heavy duty suspension and axles, and it just keeps pulling no matter what. the wheel bearings go bad often i have heard and i had to replace both of mine too. the mileage isnt a big bother because i dont need to drive mine everyday, when it kicks or i need to replace it i must say i will miss it. the "Beast-hemoth" has served me well.
#54
#55
450 lb-ft was not all that much, true, but considering it was at 2400 RPM, that's pretty significant. Peak HP was ~310 @ 4000 RPM.
When you consider a 460 with only 500cc less displacement only made something like 230HP during the same time period, and only 390 lb-ft of torque, it is pretty impressive.
#56
Yes, very impressive compared to just about the worst emissions-choked motor ever made. The 460.
8 liters, 450 ft/lbs, that's 56.25ft/lbs per liter.
The 2-valve V10 at 6.8, even non PI head in 1997, put out 410ft/lbs at 2750RPM (a whole 350RPM more than the Dodge). That's 60.29ftl/bs per liter.
#59
never had a ford v10 but can only go by what others who ran them say and the overall consensus i got from most people was "gutless" sorry, but nobody ever said that about my dodge. usually it was cummins guys and they loathe powerstroke,,and all that blah blah blah. alot of people slam the king ranch package too, bang for the buck i'd take any comparative ford any day.
#60
Thank you. The truck V10 was developed first, then the viper engine was spawned from it. It was sent to lambo (which chrysler owned at the time) for them to design the aluminum block, because a cast iron V10 was too heavy for a sports car.
