Starts but quits???
Starts but quits???
Hi, just got a 99 EB with the 5.4 and It's been a marvelous truck until this morning... It starts fine, but as soon as you let off the throttle it dies (immediately) no rough idle, just dies. It was close to freezing over night, but it is in the garage. Any ideas as to what is causing this???
Thanks! Craig
Thanks! Craig
Starts but quits???
If it still dies after warm up, you may have a bad throttle position sensor. I hesitate to say that as this is fairly new vehicle and the TPS usually lasts several years before giving problems. Checking for stored memory error codes may give an indication as to the problem.
Starts but quits???
I had this problem. Turned out to be the Idle Air Control valve. I removed mine and ran the tests listed in the Haynes manual. The unit tested within spec, so I cleaned out the carbon with brake parts cleaner and a pipe cleaner, reinstalled and it ran fine. Regarding the tests in Haynes' manual, the IAC ohms were 11.0, the manual said the range would be between 6 and 13 ohms.
Encho
21
12-17-2015 07:54 AM
bhs34
03-23-2008 10:13 AM
