Starts but quits??? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Starts but quits???
Old 02-06-2002, 09:52 AM
cferris cferris is offline
cferris is starting off with a positive reputation.
Post Starts but quits???
Hi, just got a 99 EB with the 5.4 and It's been a marvelous truck until this morning... It starts fine, but as soon as you let off the throttle it dies (immediately) no rough idle, just dies. It was close to freezing over night, but it is in the garage. Any ideas as to what is causing this???
Thanks! Craig
Old 02-06-2002, 02:05 PM
Y2K350's Avatar
Y2K350 Y2K350 is offline
Y2K350 is starting off with a positive reputation.
Starts but quits???
It could be water in your gas. going from the cold exterior to a warm interior can cause condensation in your gas tank. Try a bottle of Heet and see if that helps.
My other Truck is a Ford too.
Old 02-06-2002, 02:29 PM
aerocolorado aerocolorado is offline
aerocolorado is gaining momentum as a positive member of FTE.aerocolorado is gaining momentum as a positive member of FTE.
Starts but quits???
If it still dies after warm up, you may have a bad throttle position sensor. I hesitate to say that as this is fairly new vehicle and the TPS usually lasts several years before giving problems. Checking for stored memory error codes may give an indication as to the problem.
Old 07-28-2002, 10:06 PM
buzzard's Avatar
buzzard buzzard is offline
buzzard is starting off with a positive reputation.
Starts but quits???
Old 07-29-2002, 11:34 AM
Volman Volman is offline
Volman is starting off with a positive reputation.
Starts but quits???
I had this problem. Turned out to be the Idle Air Control valve. I removed mine and ran the tests listed in the Haynes manual. The unit tested within spec, so I cleaned out the carbon with brake parts cleaner and a pipe cleaner, reinstalled and it ran fine. Regarding the tests in Haynes' manual, the IAC ohms were 11.0, the manual said the range would be between 6 and 13 ohms.
Old 07-31-2002, 12:15 PM
One more thing can cause the engine to start but not idle is the EGR valve stuck wide open, so if your IAC valve tests OK, check the EGR. Also, EGR valves are NOT available at AutoZone or Napa yet. Dealer only.
74 Ford F100 w/ 360 lost spark last night craigibc 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-26-2009 09:28 AM
Dead / Dying Starter? cdorroh 1967 - 1972 F-100 & Larger F-Series Trucks 16 09-09-2007 04:19 PM
Where does water go without carpet? cef2lion 1999 to 2016 Super Duty 4 12-19-2005 06:56 PM
Lift and Tires ? jeeepxj 1999 to 2016 Super Duty 3 04-26-2005 02:13 PM
01 Camshaft Position Sensor Craig64 1999 - 2003 7.3L Power Stroke Diesel 19 02-28-2004 10:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
