Rear main oil leak - Ford Truck Enthusiasts Forums
Rear main oil leak
Old 12-30-2009, 10:51 PM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to behold
Rear main oil leak
I have had a small rear main leak for some time now.Yes,the dust cover will have oil in it and I have pulled it to find oil on the rear main area of the pan.Not coming from up top.Any ideas on how to fix this?Not pulling the motor for just a small leak.Live with it?
Old 12-30-2009, 11:58 PM
B-Ryan 02's Avatar
B-Ryan 02 B-Ryan 02 is offline
B-Ryan 02 is starting off with a positive reputation.
You could pull the tranny instead.
Old 12-31-2009, 12:57 AM
Layson's Avatar
Layson Layson is offline
Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.
Can you see where it is leaking? Are you sure it is the rear main? 99% of the time the oil is from the HPOP, HPOP lines, Turbo Pedestal, CC oil out of the intercooler tubes, Exhaust Back Pressure Valve, Valve cover, or maybe even the fill tube... I would drop a hose in the valley and wash it out real good. Then let it dry and then start watching it.
Old 12-31-2009, 07:41 AM
riverrat41's Avatar
Quote:
Yea...sorry to say that the valley has been dry for a long time.When we changed my wheel and donuts there was not any oil present.Pedistal has been plugged.I am very sure it is the rear main.I will get Chris(F350-6) to look at it the next time we are together.The bolts are tight and I guess the silicone is not holding.Leaks more on longer(4 hour)trips.
Old 12-31-2009, 08:10 AM
12ozd's Avatar
12ozd 12ozd is online now
12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold
Quote:
Exactly the way to do it!
Old 12-31-2009, 11:48 AM
Layson's Avatar
Well that sucks...
Rear Main Seal Leaking my996duc1 6.7L Power Stroke Diesel 10 07-13-2012 09:18 PM
390 rear main seal leak mikev 1967 - 1972 F-100 & Larger F-Series Trucks 7 11-12-2010 03:01 PM
Rear Main Seal is Leaking OutlawNomad Excursion - King of SUVs 15 03-26-2010 01:18 PM
Crankshaft endplay? Help! plgebbia 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-15-2010 11:53 PM
Where's my leak? cturk499 Oil & Lubrication 3 10-12-2004 08:41 PM
Tags
2001, 2003, 350, 60, 73, 75, cover, diesel, dust, f350, ford, leak, litre, main, oil, powerstroke, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
